Ticket Created
CIQQA-864
java.lang.NullPointerException while compiling on Kubuntu 21.10 with newer SDK's
This is some issue I experience for some time. Atm, I use Kubuntu 21.10 but I had it in previous versions too. First I need to search and install many packages due to old Ubuntu dependencies. Later I install Eclipse, plugin, SDK etc. SDK 3.1.9 works fine and I can compile and run an app from Eclipse. However, it's old and it doesn't support lots of newer devices. So I install any later SDK via SDK manager and install all the devices. However, it doesn't compile then. I tried Visual Studio Code instead of Eclipse and also tried to run the command inside the terminal. I only got a NullPointerException with some DevicesJsonReader.java file.
A try with a watchface sample named DenemeVC:
Executing task in folder DenemeVC: /home/sis651/JAVA/jre1.8.0_311/bin/java -Xms1g -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar /home/sis651/.Garmin/ConnectIQ/Sdks/connectiq-sdk-lin-4.0.7-2021-11-29-437ff4cc4/bin/monkeybrains.jar -o /home/sis651/DEV/workspace/DenemeVC/DenemeVC.prg -f /home/sis651/DEV/workspace/DenemeVC/monkey.jungle -y /home/sis651/DEV/ConnectIQSDK/developer_key.der -w -d d2charlie -r <
ERROR: null
at com.garmin.connectiq.common.devices.DevicesJsonReader.parseResolution(DevicesJsonReader.java:584)
at com.garmin.connectiq.common.devices.DevicesJsonReader.loadDeviceFromElement(DevicesJsonReader.java:398)
at com.garmin.connectiq.common.devices.DevicesJsonReader.read(DevicesJsonReader.java:321)
at com.garmin.connectiq.common.devices.DevicesJsonReader.read(DevicesJsonReader.java:304)
at com.garmin.connectiq.common.devices.DevicesJsonReader.read(DevicesJsonReader.java:302)
at com.garmin.monkeybrains.devices.DeviceManager.readStreamIntoDevicesJsonReader(DeviceManager.java:48)
at com.garmin.monkeybrains.devices.DeviceManager.<init>(DeviceManager.java:71)
at com.garmin.monkeybrains.Monkeybrains.loadDeviceManager(Monkeybrains.java:438)
at com.garmin.monkeybrains.Monkeybrains.run(Monkeybrains.java:2490)
at com.garmin.monkeybrains.Monkeybrains.simpleMain(Monkeybrains.java:339)
at com.garmin.monkeybrains.Monkeybrains.main(Monkeybrains.java:368)
usage: monkeyc [-a <arg>] [-b <arg>] [-c <arg>] [-d <arg>] [-e]
[--Eno-invalid-symbol] [-f <arg>] [-g] [-h] [-i <arg>] [-l <arg>] [-m
<arg>] [-o <arg>] [-p <arg>] [-r] [-s <arg>] [-t] [-u <arg>] [-v] [-w]
[-x <arg>] [-y <arg>] [-z <arg>]...
I had tried to dig it a bit more and I remember it was about something like sizeKey is missing somewhere. 3.1.9 works fine, but anything later results in the same NullPointerException. It happens with all my apps and devices I choose.
Anyone has an idea?
  • Hi, from the strace, I can see that it read compiler.json completely (in two read), and data looks correct.
    I installed Kubuntu 21, and the SDK, even in Turkish, and I had no issue.
    Can you try to build the Analog sample, using monkeyc ?
    Something like:
    $HOME/.Garmin/ConnectIQ/Sdks/connectiq-sdk-lin-4.0.8-2022-01-20-c823f71a9/bin/monkeyc --jungles $HOME/.Garmin/ConnectIQ/Sdks/connectiq-sdk-lin-4.0.8-2022-01-20-c823f71a9/samples/Analog/monkey.jungle --device fenix6 --output Analog.prg --private-key $HOME/key.der --warn
  • I added the log in my previous comment.
  • Hi. Sorry for the long response time. I was very busy at work and tried a few things without success. I ran the command with both OpenJDK and Oracle JDK and add the strace logs.
    build-log-openjdk.zipbuild-log-oracle.zip
    Logs are created for Fenix 6. A strange thing is when all the devices are downloaded in manager, according to strace it someway loads the compiler.json file of fenix 3, no matter the device I choose. And if I delete that file, it loads the Edge 530 compiler.json file. In order to be sure it loads only fenix 6 I removed all the other devices from manager. I think there is some issue with accessing the compiler.json or reading with it.
  • Can you do a:
    strace -s 8192 -f the_command_you_use-to_build >build.log 2>&1
    and share the build.log file please ?
    (Under linux, and you might have to install strace)
  • It happens with all code. CIQ SDK 3.1.9 successfully compiles and runs them. However, later versions has a problem in my setup. Even, I create a new project using the samples and the same happens. The strange thing is I didn't think the same was going to happen in VirtualBox Windows setup. :)
