Acknowledged
I'm creating a ticket to find out why this flag is required and whether it's something we can improve.
Connect IQ BLE scan issue
**UPDATE** Found the reason. The watch will never (in our case) find a scan result from a BLE device which doesn't advertise General Discoverable Mode. However, running your FW on a nRF dongle will get those scan results. I'm not sure the reason why they behave differently. But I guess we can hope that you support getting scan results from devices which doesn't advertise General Discoverable Mode in the future, just like android, iOS, wearOS and watchOS does.
I have an application which starts BLE scanning and then shows the result. It does however work drastically different on a simulator vs an actual watch:
- If I run it on the simulator for Fenix 6X PRO with a nRF plugged into my computer then I see all the desired scan results from devices that are nearby. The app will find almost all the nearby devices and the scan results will properly contain the device name, service UUID etc.
- If I build the app, put it on my Fenix 6X PRO watch and then launch it then it works very intermittently. For some periods of time it doesn't get any scan results. Other periods it will get 1-3 different scan results over and over again, and it's never the result of the desired device.
Our peripheral device advertises regular BLE with a service UUID of 128 bits. The results we see on the watch are only for devices which advertises 16-bit service UUIDS.
Example of results I do get on the watch when doing BLE scanning:
- FE50 (0000FE50-0000-10000-80000-00805F9B34FB) with name Google
- 1523 (00001523-0000-10000-80000-00805F9B34FB) with name TT214H BlueFrog
- FE4D (0000FE4D-0000-10000-80000-00805F9B34FB) with name EBDMR-CB-DD (Casambi)
The names here have been gotten from nRF connect b/c the watch always thinks that the name (scanResult.getDeviceName()) is null.
What can be the reason for the app functioning so differently on a simulator and a similar watch? Why does it only show some scan results?
I have also tried with BleScan on that same watch and it gets the exact same scan results as I get in my app. Why does that watch only get those results?
  • Hi, thanks for the response. If you read the last part of my post you see that I tested your app and found that it got me the same results as my own application. So those 3 UUID's that I wrote about are more or less the only 3 I get when I run your BleScan app.
    When you do a 16 bit UUID you typically use 0x02 or 0x03 as the common data type and then your 2 byte UUID. This translates to the UUID + base UUID seen in the app.
    I can see that the devices that I get results of advertise their UUID in that way.
    Our device has 0x07 as common data type and a 128 bit UUID.
    When I run in the simulator using the nRF dongle everything works perfectly.
    On a similar Watch (Fenix 6x pro) I only seem to ge the 16 bit UUID responses.
    Our full raw advertise data is 29 bytes long (so shorter than some that are actually found which are 30 bytes long). So we have a flag 0x04, then our 128 bit UUID and then our 9 byte local name.
    Is it just that simple that Garmin watches only support 16 bit UUID's? I find it very strange that they never mention that anywhere.
  • First thing is make sure you watch the breakout session where this was announced
    https://forums.garmin.com/developer/connect-iq/b/news-announcements/posts/adding-bluetooth-connectivity-to-your-connect-iq-projects
    Understand this is a very limited implementation on the garmin devices, where things like the amount of data you can receive is minimal. no security, you need to define your services and characteristics in your app, you don't always see names and/or UUIDS, etc, and you are limited to .registering at most 3 profiles.
    Without seeing your code, what I usually suggest is a simple hack to the NordicThingy52 sample in the SDK to see what's happening with scanning.  In the ThingyDelegate.mc, add the following line to contains, and you'll see everything seen when scanning
        private function contains(iter as Iterator, obj as Uuid) as Boolean {
            for (var uuid = iter.next(); uuid != null; uuid = iter.next()) {
    //Add this line
    //System.println(uuid.toString());
                if (uuid.equals(obj)) {
                    return true;
            return false;
    As far as the real device, I have an app that shows you exactly what the Garmin can see with scanning and you can see a time stamp for when the scan result was seen.
    https://apps.garmin.com/apps/9bcc8b66-8385-4afb-b93e-f69e01422284
    Different size UUIDs also come into play,  For example, I need to use the base UUID for a BLE HRM.
    //Using 16 bit UUIDs
    //Ref. the Bluetooth Core Specification 5.2, Vol 3, Part B, section 2.5.1 UUID:
    //The first UUID in this pre-allocated range is known as the
    //Bluetooth Base UUID and has the value 00000000-0000-1000-8000-00805F9B34FB
    //The full 128-bit value of a 16-bit or 32-bit UUID may be computed by a simple
    //arithmetic operation.
    //128_bit_value = 16_bit_value * 2^96 + Bluetooth_Base_UUID
    //128_bit_value = 32_bit_value * 2^96 + Bluetooth_Base_UUID"
    //What it means in practice, is that you take a "base UUID" of 0000xxxx-0000-1000-8000-00805F9B34FB,
    //and replace the x-es with the 16 bit UUID.
