Ticket Created
WERETECH-12052
Conflict/race between makeWebRequest and Storage.setValue called from onUpdate on a watchface.
Hi, I was able to reproduce the following problem (both in simulator and in a Descent MK1 using SDK 3.2.5 and 4.0.6):
If the function setValue is called from onUpdate while makeWebRequest is still waiting for the webserver to return data,
the callback function is "lost" (and not called).
The following code reproduce the problem 100% of the time.
using Toybox.Application;
using Toybox.Background;
using Toybox.System;
using Toybox.WatchUi;
using Toybox.Time;
using Toybox.Communications;
using Toybox.Application.Storage;
(:background)
class PiServiceDelegate extends Toybox.System.ServiceDelegate {
  function initialize() {
    System.ServiceDelegate.initialize();
  function onTemporalEvent() {
    // That URI takes about 3 seconds to answer
    var uri = "https://wb.elaine.fi/pi_slow";
    System.println("Before query");
    var options = {
      :methods => Communications.HTTP_REQUEST_METHOD_GET,
      :responseType => Communications.HTTP_RESPONSE_CONTENT_TYPE_JSON
    Communications.makeWebRequest(uri, null, options,
                                  method(:pi_received));
  function pi_received(code, data) {
    System.println(code);
    System.println(data);
    if (code == 200) {
      Background.exit(data);
(:background)
class PiWatch extends Application.AppBase {
  public function initialize() {
    AppBase.initialize();
  function onBackgroundData(data) {
    System.println("onBackgroundData: " + data);
  function getServiceDelegate() {
    return [new PiServiceDelegate()];
  function getInitialView() {
    Background.registerForTemporalEvent(new Time.Duration(5 * 60));
    return [new PiWatchView(), new PiWatchDelegate()];
class PiWatchView extends WatchUi.WatchFace {
    WatchFace.initialize();
  public function onUpdate(dc) {
    System.println("onUpdate");
    // On simulator, onUpdate is ran every seconds
    // So we will call Storage.setValue between the http request
    // and the result
    // On watch same problem exists
    Storage.setValue("foo", "bar");
    // Note that problem does not exists if Storage.setValue
    // is called in onPartialUpdate
class PiWatchDelegate extends WatchUi.WatchFaceDelegate {
    WatchFaceDelegate.initialize();
Here is the output:
onUpdate
onUpdate
onUpdate
Background: Before query
onUpdate
onUpdate
onUpdate
Error: Symbol Not Found Error
Details: Failed invoking <symbol>
Stack:
onUpdate
onUpdate
onUpdate
If I comment the setValue line, I get the expected result:
onUpdate
onUpdate
onUpdate
onUpdate
onUpdate
onUpdate
onUpdate
Background: 200
Background: {pi=>3.140000}
onBackgroundData: {pi=>3.140000}
onUpdate
onUpdate
onUpdate
  • So, I did the test you suggest (test for having storage and register on onExitSleep).
    Same issue. (tested with sdk 4.0.7)
    output:
    we have storage
    onUpdate 8
    we have storage
    onUpdate 9
    onExitSleep
    we have storage
    onUpdate 10
    we have storage
    we have storage
    onUpdate 15
    we have storage
    onUpdate 16
    we have storage
    onUpdate 17
    we have storage
    onUpdate 18
    we have storage
    onUpdate 19
    Stack:
    we have storage
    onUpdate 20
    we have storage
    source:
    using Toybox.Time;
    (:background)
        var uri = "">https://wb.elaine.fi/pi_slow";
        var options = {
    (:background)
      var i = 1;
        i += 1;
        if (Toybox.Application has :Storage) {
          System.println("we have storage");
        System.println("onUpdate " + i.format("%d"));
      public function onExitSleep() {
        System.println("onExitSleep");
  • As I've said, setValue is expensive, and really not something you want to do all the time in onUpdate, as it will also impact your battery life,  Only call setValue when you need to - do it in onBackgroundDate instead for example.  The most it will be called then will be every 5 minutes.  Or, as I mentioned before you only really need to do it in onStop for the main app,
  • on sim it's to short probably to get watchdog
    Have test "has  for storage" to exclude error in onUpdate?
    Move
    to PiWatchVie.onShow or batter to onExitSleep()
  • So, now that the onPartialUpdate/budget exceeded case is cleared, I tested the following:
    Long loop on onUpdate, just enough to not trigger the watchdog.
    In that version, we do not call setValue, and there is no problem.
    using Toybox.Time;
    (:background)
        var options = {
    (:background)
      var i = 1;
        i += 1;
        // 6000 is sweet spot, 7000 triggers the Watchdog
        for(var j = 0; j < 6000; j++) {
          var k = Math.sqrt(j);
  • The order that these calls happen can vary, and it's something you need to account for in your code.  onAppUpdate/onAppInstall will happen before getInitialView, and even if you don't override them, getserviceDelate will be called.  And then there's the thing in your appBase (initialize(), onStart. onStop, etc,) that are called when the main app or the background service runs.
