There are several issues with the available compilers (SDK 4.1.7 and SDK 4.2.0 Beta 1) if a class contains a static function and the parameters of the function are Monkey Typed with the compiler set to "Gradual" or higher.
- Cannot find symbol errors for functions on core classes (eg. Position.Location); and
- Error parsing the global namespace ($.) when specifying the Monkey Type for a function parameter.
I tried the broken, replicateable code on SDK 4.1.5, SDK 4.1.6, SDK 4.1.7 and SDK 4.2.0 Beta 1.
Error #1 occurs only on SDK 4.1.7 (ie. it works fine on SDK 4.1.5, SDK 4.1.6, SDK 4.2.0 Beta 1).
Error #2 occurs on all the SDKs listed above -- SDK 4.1.5, SDK 4.1.6, SDK 4.1.7 and SDK 4.2.0 Beta 1.
These errors may or may not be related to this issue: https://forums.garmin.com/developer/connect-iq/i/bug-reports/bug-report-static-lang-dictionary-class-variable-broken-in-sdk-4-1-6
I am not able to attach my test project that will easily replicate both issues/bugs but I have emailed the ZIP to the Connect IQ team. If anyone would like the project file to validate the issue or use it as the basis for a similar sounding bug or just out of curiosity, then DM me. For reference, the function within the class looks like this:
static function compilerErrorOne(location as Position.Location, waypoint) as BrokenClass {
var decimalDeg = location.toDegrees();
var wpDecDeg = waypoint.getLocation().toDegrees();
var brokenClass = new BrokenClass(null);
return (brokenClass);
static function compilerErrorTwo(location, waypoint as $.Waypoint) as BrokenClass {
