Complete
over 1 year ago
Cannot get location of GARMIN weather for fenix8 series devices
Hi:
When I tried to get the location of GARMIN weather for fenix843mm, it seems that cc.observationLocationName is null. Both the simulator and real fenix8 devices reported the same issue. The SDK is 7.3.0.
Moreover, Users with other devices reported that they'd encountered the same issue after they upgraded their system of the watch.
Can somebody help on it? Thanks.
for example:
if(Toybox has :Weather) {
var currentConditions=Weather.getCurrentConditions();
if (null != currentConditions) {
// city
var cc = currentConditions as Weather.CurrentConditions;
var city;
if (null != cc.observationLocationName) {
var index = cc.observationLocationName.find(",");
city = (null != index) ?
cc.observationLocationName.substring(0, index) :
cc.observationLocationName;
} else {
city = "unknown";
  • hi, I can see the same behavior witht the SIM, with F6 for example the city name is displayed but with F8 null is returned,
    it would be great to do an annoucement about that, I've already received many mails from user about that... That is the "shame" it is deprecated, it seems many user are using it.
  • Seems to be a lot of reports of CIQ watchfaces crashing due to this change. I realize that this is entirely down to incorrectly written apps, but I wonder if it would’ve been better to return an empty string. (Yeah, I realize that would have consequences for apps that actually handle the null case properly, but probably aren’t expecting an empty string.)
    It’s probably a no-win situation here — I have a feeling that there will be some old/unmaintained watchfaces that will be permanently broken (but hopefully they all have the ability to turn off the weather feature so users can continue to use the watchface without experiencing constant crashes.
    I also wonder if this kind of thing merits an annoucement in the CIQ forums, so at least any developers who are watching the forums would have a heads up.
  • This was identified during beta testing of the fenix 8 products and we enquired about it. Without getting into too much detail, the location names we were receiving were often incorrect, so the product team has dropped support for the location name in firmware. Since this renders the observationLocationName in CIQ basically useless, we're going to deprecate that particular member of the Weather API.
  • I also started seeing this with a 965.
    At one time, the locationName was the city I was actually in (it would change if I was in the town right across the freeway), then it changed to the actual location of the weather station (in my case, it was the main airport), and then changed again to being null.
  • hi, I can also confirm this behavior, on real Fenix7PRO with 17.28: ok, same with 18.13, null is returned on observationLocationName
