Hello,
I'm experiencing a persistent issue with Connect IQ data fields on my Garmin Fenix 7 Pro specifically related to navigation screens.
Problem Description:
When I add a Connect IQ data field to a navigation screen, it appears correctly during configuration. However, when I start a new activity with navigation enabled, the Connect IQ field is automatically replaced by the default Timer field.
Steps to Reproduce:
- Go to Navigation Settings → Data Screens
- Add an additional navigation screen
- Add a Connect IQ data field to this screen (any Connect IQ field)
- Save and exit
- Start a new activity with navigation enabled
- Result: The Connect IQ field has been replaced by Timer
What Works:
- Connect IQ fields work perfectly on regular activity screens (non-navigation)
- Native Garmin data fields persist correctly on navigation screens
- The configuration appears saved until the activity is restarted (if go to navigation settings during an activity)
What I've Tried:
- Multiple different Connect IQ data fields from the store
- Developing my own custom data field using Connect IQ SDK 5.2 with API Level 5.2
- Latest firmware version on Fenix 7 Pro
- Removing and re-adding the fields
- Different activity profiles
Device Information:
- Model: Fenix 7 Pro
- Firmware version: 25.11
Question:
Is this a known bug? Are navigation screens supposed to support Connect IQ data fields, or is this a limitation? It seems inconsistent that native fields persist but Connect IQ fields don't.
Any workaround or fix would be greatly appreciated.
Thank you!
