Acknowledged
CIQQA-4261
BLE not working in simulator after updating to SDK9.2
I'm trying to simulate one data field that uses BLE to connect with sensors. It was working fine until I have updated to SDK9.2
Now, it seems dongle is not available for the simulator. Going back to SDK9.1 still works fine.
Tested in macOS Monterrey
Release notes mention two changes related to BLE. They may have some relation.
New Features
  • Add bonded connection support in the simulator.
Bug Fixes
  • Fix issue where the simulator crashed when launching a BLE app when the dongle was not connected.
Anyone can try to reproduce this and confirm?
  • but who can you switch from 9.1 to 9.2, while the SIM 9.1 is running?
  • What I've found with my pi based sensors, if I use the 9.1 SDK, and "OK" using an open connection then switch to 9.2, I can run just fine, but only with the sensor I OK'ed.
  • I am seeing the same thing.
    With the older firmware everything works until I go to SDK 9.2.0. SDK 9.2.0 does not work with the older firmware.
    With the newer firmware, SDKs older than 9.2.0 results in System Error, Profile Registration Unhandled Error. I was not expecting this to work.
    But with the newer firmware and SDK 9.2.0, scanning works, but I get no data after connect, so for me SDK 9.2.0 effectively breaks BLE work.
  • i found, that with 9.2.0 in simulator a BLE connection
    - works, with a device using BLE v5 (Laird BL652 chip), data is incoming after connect
    - is not working, with a device using BLE v4 (HM10 module), no data after connect, and connections drops after a few seconds with state=0 (disconnect)
    This issue is not seen on real device (Edge 1050 and Vivoactive 6)
  • I have a BLE datafield which is stable working with 8.4.0, in simulator and on device. With 9.2.0 in simulator (nrf dongle updated to softdevice 140) the datafield scans, pairs and connects, but immediately disconnects. After 3 times, there are no further connetcs. The same code does not show this issue on a real device.
    Code is here:
    https://github.com/cyberman54/Forumslader-Companion/tree/main/source
