Acknowledged
22.22 FR165 DrawRadialText symbol not found
Since the last update, 22.22, method Dc.drawRadialText stopped working on the FR165 and FR165m.
It works fine in the sim, but crashes on a real device with error "Symbol not found".
I reported this last month when it was still in Beta as well:
https://forums.garmin.com/beta-program/forerunner-165-series/forerunner-165-series---bug-reports/i/public-beta-version-22-xx/drawradialtext-symbol-not-found-in-dc
Now the software is rolling out, apps that use this will method will crash (including two of my watchfaces) with no easy way to work around this.
  • Then remove the 165/165m from your supported devices until this is fixed.  I've done that in the past for other issues on other devices.  In one case the fix took over a month.
  • Jim, it won't make the customer happy to have a completely messed up watch face (they paid for) due to wrong layout / font size text angle etc. instead of a crash. They'll come back to the developer, not to Garmin on this. It's the dev who needs to reply to dozens of emails and explain the issue. Some people want a refund...
  • They both use the result of getVectorFont.  So "has" check that, and if has shows true, also check that what you get back isn't null, and if it is, don't use drawRadialText or drawAngledText.  That's what I've done since scaled/vector fonts were introduced.
    You may also want to add "has" checks for drawAngledText and drawRadialText for extra protection
  • It is not just drawRadialText() but drawAngledText(), too
  • We're looking into this and will be working on a fix. In the meantime, using has checks will prevent the crash. I can confirm this is only affecting the fr165 and fr165m.
