WatchApp : Gym Set/Rest Timer
Attention : As of Sept 1st
Max Usage time per month implemented. Last NON-PRO version.
This was created to serve an itch of my own. I am a forgetful person and after a while, I lose count on the number of sets I've already done.
Hence this solution.
The app has 3 items on it only.
Set : This is to show remind how many sets has been done. e.g. 3sets of 15 reps each. (you will keep count of the reps yourself)
Rest : This is the time in between sets. Per normal instance, Weight Lifting would have a recommended rest time of say 60secs (countdown timer)
Timer : This is just a stopwatch to show how long is the total workout time - inclusive of rest time.
The StartStop key starts and stops the stopwatch (this version will not pause it - looking in to how to do start/pause/stop)
The UP key will increament the # of sets.
The DN key will Reset the # of sets back to 1. (e.g: if you do a 5x5, at the end of the 5 set, you would press the DN key and reset it back to Set 1 for the next session.
Method of usage.
1) Start stop watch
2) start first set (x number of reps)
3) Press Up to increment Set. this sets off the Rest Timer (60 secs)
4) once The Rest Timer counts down to 0 secs, (last 5 secs will have a vibrate function) then you begin your actual 2nd set
  • Uploaded a brand spanking new version to the store.
    Minor bugs
    Awesome app but rest interval for 120 seconds only sets to one second on Epix. Also resume command resets work and rest intervals.
  • Hi -
    Thanks for the bug report. Fixed. and uploaded to the App store.
    typo in my part during testing to reduce wait time. :-p
    as for the resume - it's the way it is designed. In My View - when you pause - you could be doing like 15secs of work only w/ 15secs to go, but since you decided to stop it for x reason (tired, talking to someone etc) then you have lost the rep for that set. You need to start over)
    Even if you use it for running for e.g., if you stop it, that particular session is over.
    That are my use case scenario.
    Tell me yours and I will think about it / logic etc..etc..
  • New version uploaded.
    Can I ask users of 920 / epix to take a screenshot of it and post it? I changed the fonts and wanna see how the layout looks.
    Many thanks.
  • Epix Image of Gym Timer
    Sorry, man. I've been trying to upload a picture through this screwy upload system they have on this forum and it just doesn't work. Will try emailing it to you directly.
  • appreciate it.
    Uncanalways put a Dropbox link here. That works better.
  • anyone here has issues w the current version and the GymTimer? Vibration out of control?
    That's what the review says but as usual - since I have no way to contact that reviewer - I may just have to ignore the comment / review.
    How to fix when I can't get a clue as to what he/she is experiencing. Haiz.....
    Darco
    August 18, 2015
    Version 1.0.4
    New version doesnt works fine at all. Previus version was great for my workouts but currents get crazy and start to vibrate without control. I would like to install the prevous one but seems is not posible..
    Well, it would be possible if he contacted me or put the feedback here.
    Thanks for fixing small bugs!
    Great app, just sent you an email to get PRO version!
  • I would still like to see how the app looks on an epix watch.
    I recently found out that the chars on Epiznis too large for the GymTimer. Hence, next version will fix this along with a better buzzer countdown.
    I've also added ability to input an unlock code. It's a crude hack but at least it works!! (Keyboard is not supported under the VA)
    VicoActive First use
    Well not happy, sat last night and set the app up
    Went to gym to day
    Knocked my pan in for over an hour
    Saved session
    got home
    Synced data
    NOTHING
    NO DATA FOUND FOR TODAY all that was uploaded was my steps for today..
    Any other Gym apps available ?
