DataFields : 367 RunFields
Update 2015-09-15
Have started to upload V2 of the 367Bike and RunFields to the App store.
367BikeFields is Live.
367RunFields is Live
The new version adds TimerTime, also adds the seconds on the timer once you reach > 1hr. (I'm told that seeing seconds is especially important for runners)
Note for all : Please refer to the app store for the latest in the NEW direction the app/datafield is going.
Go PRO! GO UnLimited!!
  • TOD (Time Of Day)
  • Timer Time
  • Pace 10s / Current Speed (in KM or Miles)
  • Cad
  • HR
  • Dist (either Miles or KM)
  • Avg Pace / Avg Speed
Many Thanks to SimonMcMullen for his code guidance.
Many Thanks to TORSTEINVH for his guidance on how to make an moving average (tho it's still a hack and not pretty code)
367RunFields-VA - http://apps.garmin.com/en-US/apps/0d38cc9d-78d9-46e1-85d4-9b4b2742a4bc
367RunFields-F3 - http://apps.garmin.com/en-US/apps/01ff5476-3b6a-499f-9253-404724f5d642
367RunFields-920 -http://apps.garmin.com/en-US/apps/f7daa40d-bc9d-4456-ad12-65cf43e5782c
367BikeFields-VA - https://apps.garmin.com/en-US/apps/8469d7cf-07af-4046-9a5e-c9c6345b219a
367BikeFields-F3 - https://apps.garmin.com/en-US/apps/617b1adc-c42e-46e2-aac9-1ab56618971e
367BikeFields-920 - https://apps.garmin.com/en-US/apps/e2e00ba3-452b-4798-8b5d-f272fc7cbe63
For Full configurability of all the fields in the 4 datascreens offered, take a look at these apps
F3 : https://apps.garmin.com/en-US/apps/b...9-2fcfefdf466d
VA: https://apps.garmin.com/en-US/apps/1...1-937d99f95fea
920: https://apps.garmin.com/en-US/apps/0...b-35c893b25356
Also has :
Time in zone.
Virtual partner
Generic Recorder: - for other activity profiles which are not Weight Lifting / Running and Biking
https://apps.garmin.com/en-US/apps/b...a-23afd94009c4
    Former Member over 10 years ago
    my Watch is 4.20 and CIQ is 1.1.3
  • thanks for posting here. I saw ur review of the store and was already ready to ignore you (cos I reviews or comments on that site is non actionable)
    I will take a look at it with my F3 as well. (So at least if it does not works for me... )
    What Watch firmware version as well as CIQ version are you??
    First shot here and the field appears to not launch (simply get the "IQ!" screen)
    FW 4.20
    Display 2.10
    BLE/ANT 3.10
    WiFi 2.00
    ConnectIQ 1.1.3
    same as my watch.
    Interference between 367 RunFields and Watch faces
    I discovered a strange phenomena, each time I have 367 RunFields activated in one of the Data Screens the watch display defaults back to just a digital clock with the ring displaying the seconds. If I try to change the watch face back to e.g SC1 it does not accept the change. It is only that after a while (3 to 4 min) that then the change of the watch face is accepted by the F3.
  • I'm not able to replicate the IQ! error on my watch. It's an F3.
    FW 4.20
    Display 2.10
    BLE/ANT 3.10
    WiFi 2.00
    ConnectIQ 1.1.3
    I am unable to download and install the one directly from the App store. I am using my locally created copy (the one uploaded to the app store)
    If any of you have your charging cable w/ you. Here is what I am using and it works.
    https://www.dropbox.com/s/ct9n8hmm3q7oxth/367RunFields.prg?dl=0
    Can you also put in some logging?
    In WATCH\GARMIN\APPS\LOGS
    Please put an EMPTY TXT file w/ the following name (only if you use the dropbox file above)
    367-F3.TXT
    CIQ_LOG.TXT
    Run the App, then Copy/paste the content of the TXT File here after it shows the error.
    EDIT : Are you guys by-chance installing it on DATAScreen 1 (DS1)? I have it on DataScreen4. I tried to put it in DS1 and I get the IQ! Error Logo.
    i can't see any file on you dropbox on above link and also i has tried on DS1 another DS also same error IQ Error
  • Yep - Datascreen 1 - where it's always been.
    CIQ_LOG.TXT is here - https://www.dropbox.com/s/t5n4smperbticiv/CIQ_LOG.TXT?dl=0 - I've not uploaded 367-F3.TXT since it remains at 0 bytes.
  • I _think_ i may have found the issue. the simulator is not capturing the issue. Only the watch is and under some circumstances only.
    In my quest to optimise the code, I've moved some of the variable default values / declaration and this resulted in some NULLs, (which I tot I've handled but it seems that during app start-up, these nulls are not handled _until_ the app starts running.
    I'll recompile and re-upload.
  • Happy to try a test version before you re-publish to the App-store if that speeds the test cycle? (I'm most interested in 367Bike)
    Yes, i also happy to testing before you put to App-store, :D and i also use 367 Run and 367Bike :)
