WatchApp: Rowing Pace
Please use this thread to report any issues or problems you are having with the application.
App: https://apps.garmin.com/en-US/apps/4df70520-6d7f-4ceb-929a-bf610c4303e6
DESCRIPTION:
Application which displays information about a given rowing pace.
FEATURES:
- displays information about different distances and times for a given pace
- displays the average wattage for a given pace
- displays estimated calorie expenditure
CALORIES NOTE:
The calorie numbers are based on formulas provided for the Concept2 indoor rower. This calculation is only an ESTIMATE and is assumed that a consistent pace is rowed throughout the workout. The calories burned uses the weight from the user profile to estimate true calorie use.
INSTRUCTIONS:
1. Set the desired pace : hold menu and enter a desired pace/500m
2. Select START/ENTER to view pace information for pre-determined distances and times (scroll through using UP/DOWN)
NOTICE:
This application was tested on a fenix 3 using firmware version 3.10.
CHANGE LOG:
Version 1.0.1:
- added calorie use estimates
Version 1.0.0:
- initial release
    Former Member over 9 years ago
    I know have the fenix 3 and still no conection for the erg :o(
  • This particular app is just a digital pace chart for the rowing machine. That being said, I am working on getting an application for getting your rowing session into Garmin Connect. At this point I have determined that it will work and can get data from the PM using ANT. Once I have something far enough along I will reach out to you for testing. Please keep in mind that even once I have everything working it can't record the data to a FIT file until Garmin updates CIQ with that functionality.
