Widget: PositionPlus
***UPDATE*** Please note that I no longer use a Fenix 3 and no longer have the time to maintain and upgrade this app. Sorry for this and thanks to everyone who posted feedback over time, I built this app for my own needs and I was quite surprised to see that it was useful to quite a few people! At this point I'm mostly using the Gaia GPS app on my iPhone 6 (with the iPhone in a rugged battery case for better grip and extended battery life - Beetle Sport Power Pack) plus the Gaia GPS Apple Watch extension for a quick look at the map/stats on the wrist. I still have an Oregon 600 as a backup but I sold the Fenix 3 as it was just sitting in my drawer.
PositionPlus Widget
This is a widget I initially wrote for my own use on my fenix 3 but thought to make it available on the Connect IQ app store and was very positively surprised by how many people found it useful! :)
On launch, the widget will first aquire GPS signal after which it will display the current latitude and longitude (in either degrees/minutes/seconds, decimal degrees or MGRS format - pls choose the format you prefer by pressing [Menu] while the widget is active), the current altitude (in meters or feet depending on user settings), the current speed (in km/h or mph depending on user settings), the current heading (in degree and cardinal points format), the current time (hours, minutes, seconds), the timezone (offset from UTC in hours), whether Daylight Saving Time (DST) applies for the current timezone and the GPS signal strength (on a scale from 1 to 4, 1=no gps signal, 2=poor signal, 3=usable signal, 4=good signal). GPS signal strength will color red when there's no GPS reception and green while GPS is active and the watch will play a short alert sound and/or vibrate whenever GPS fix is acquired or lost (subject to alerts/vibration having been enabled in system settings).
*The GPS signal strength will show properly on the Fenix 3 but it will not show on the Epix, Forerunner and generally on square watches due to lack of screen real estate (square displays having less height compared to Fenix 3's round display). All other fields should show properly on all devices. I will look into using a different layout for square watches in upcoming versions.
***CHANGE HISTORY***
Changes made from version 2.1 to version 2.2:
- fixed issue where DST was reported incorrectly
- removed the vivoactive as a compatible device due to reports from users about erros (a red X showing) on the device. Unfortunately I do not own the vivoactive and the widget works when tested on the simulator so not really able to debug this. Therefore I decided to remove vivoactive support from the widget.
Changes made from version 2.0 to version 2.1:
- added feature where the watch will vibrate for 0.5 seconds and play a short alert sound when GPS fix is acquired or lost (if vibration/alerts are enabled on the device)
Changes made from version 1.1 to version 2.0:
- added ability to select coordinates format (degrees/minutes/seconds, decimal degrees or MGRS - pls choose the format you prefer by pressing [Menu] while the widget is active).
- added the time of day (hh:mm:ss), UTC offset (in hours) and a daylight savings time (DST) indicator.
- added dynamic coloring for the GPS signal strength indicator (green when a GPS lock has been acquired, red otherwise).
- updated widget layout to accommodate the newly added fields.
Changes made from version 1.0 to version 1.1:
- altitude is now displayed in either meters or feet depending on user settings
    Former Member over 9 years ago
    Hi, How can I get into the menu?
    Thanks
    DST setting incorrect?
    Hi. Love the widget, but noticed a new problem. New Zealand changed to daylight saving time one week ago. Widget changed from "DST: No, UTC+12" to "DST: No, UTC+13", when it should have changed to "DST: Yes, UTC+13".
    any suggestions?
    Using latest firmware: Fenix 3, 6.90
  • As others, I can't choose anything but MGRS...
    And MGRS reading is only "31T EA 0000000000", so, doesn't work anyway, no position.
    Compass fenix 3
    Hello,
    I would like to know if you can build a custom app for fenix 3?
    I want to lock with my watch's compass a specific point at the horizon. The app should have a big arrow that always indicate at the exact point of the horizon I was previously locked .
    Also I would like the app to work while swimming.
    Alexis
  • I know from my own testing of other apps, that MGRS doesn't work on a vivoactive (it's always zeros).
    This has been reported to Garmin, and will likely be resolved in a FW update.
  • Any chance of a FR230/235/630 version? Thanks!
  • Position format
    I have just stumbled upon this widget for my Fenix 3. What a brilliant app. Very pleased with it. Reading this forum thread I realise you cannot get the user position format from the Fenix 3's settings and you manage to select changes using a menu in the widget. Would it be possible to add degrees, minutes and decimal minutes to the options as this is a format I use extensively. At the moment I need to make an extra step each time to convert from the DMS format.
    Thanks.
    Possible app additions
    Hey there, great app, love to be able to verify my current location.
    My question is (regarding this widget or possibly a new one/app) is there a way to make the widget SEND your current location to garmin or other people as part of a distress signal? It would seem all the location information is there but trying to figure a way to share it while out of cell service would be awesome!
    Thanks in advance
  • HI
    Nice app
    I don't understand what key to press on a Fenix 3 in order to get inside the menu :/
    GREAT app!
    Great app! I love how it is a widget so doesn't stay running. I am always concerned about battery life so want to make sure things don't stay running in the background. This is a GREAT apps for taking a quick,spot location and getting on with things.
    I would like to request 2 additions.
    1) UTM coordinate system (Looks like this has been asked for before)
    2) Picking DATUMS (NAD27 vs WGS84)
    If you could do those 2 things, it would get multiple 5 star ratings!
