WatchFace White with arcs
https://apps.garmin.com/en-US/apps/27fc5673-2d7f-42c9-b399-4c42213d4e25
White background, red minutes, 12/24H mode.
Displays :
- batterie percent and a progress bar in white and gray
- steps, step goal and a progress bar in red
- bluetooth status
- sleep mode status
- distance
- calories
V 1.1
- Fix AM/PM bug in 12H mode (PM was starting at 01 instead of 12)
V 1.2
- Change arc drawing method and design (due to arc drawing) to improve performance : no more menus lags and less battery drain
V 1.3
- Back to old design due to bad graphic behavior in 24H mode after 20H
- Change (again) arc drawing method and merge some bitmaps to optimize more the performance
- 2 digits for hour in 12H mode
V 1.4
- 1 digit for hour in 12H mode (convention)
V 1.5
- No changes but this version should stop to display a vivoactive compatibility (that's not true)
V 1.6
- Handles Miles/KM display
V 1.7
- The top arc now displays the move level : empty, ok, full, you have to move !
    Former Member over 10 years ago
    Updated (see first post)
    Los arcos se ven distorsionados.
    New update, see changelog on first post
    Former Member over 9 years ago
    Battery consumption
    Hi, I think this is a great watchface, it contains almost every information I need at a glance.
    BUT I made some testing on battery consumption,and this app seems quite hungry...
    After one day of normal use with Bluetooth connection to my phone, with this watchface the battery went from 100% to 77%, that means -23% in 27 hours, I.e. a little less than 1% battery per hour. Is it normal with this app?
    Then I changed back to standard Garmin digital watchface, still with BT enabled, and the consumption was -7% in 21 hours, that means -1% every 3 hours.
    That would mean that this app consumes the battery 3 times more than the standard watchface. Is that right?
    What's the part of the watchface the the consumes the most? Step counter?
    white and green with arcs
    Please make a new version - thicker numbers and green color minute digits with a white background - white and green with arcs :)
    Dakujem z.
  • I really like this watch face, would like to see current HR added into it.
  • Feature request: it would be great if you could please show the sunrise and the sunset on the screen.
    Thank you.
