Widget: CalendarWidget
Simple calendar view.
Start button: fast rotated current, past and next month.
Press and hold menu: select month to view or change (and store) first day of week You want.
0.0.1 - Initial
0.0.2 - change
- change get current time from Calendar.new() to Calendar.today() - maybe it is problem in other timezones
- press and hold menu button to change first day of week
0.0.3 - change 920xt compatibility - test compliation
0.0.4 - test compilation for vivo and epic
- tune height layout elements to 148px displays
- add timezone offset to date (shift calendar error in 'negative' timezones after utc midnight).
0.0.5 - add menu with options:
- select year 2013-2017 and month to view
- change first day of week
    Former Member over 10 years ago
    There is a little bug in Fenix 3. When you select first day of the week Monday, there are several sequential numbers in the left side of the calendar that should be hiden
    Those numbers look like week numbers (CW) to me (also F3), and are actually very useful.
    Former Member over 9 years ago
    New design, version 2.0, add battery meter
    I couldn't find how I can change first day of week on my fenix 3? press and hold menu button.. where is the menu button on fenix3 to change first day of week :)
    second question; there is a mount. ???. year format at the bottom of the screen. whats is the second parameter. ıt shows now 20. so 11.20.2015
    finally I have suggestion, the battert meter is very bad. who need to know battery in a calender app. sorry but Its very bad decision. I think the name of the mount should be there instead of battery meter.
    so. structure is;
    mount name of the current date
    calender (it looks very cool. congratulation)
    and the date. 05.11.2015 (or 11.05.2015)
    but good work. congratulation :)
    Designs
    Hi Folks,
    thanks for the widget - I like it. And while the new design is beautiful, too, I preferred the old one for better readability (black on white is usually easier to read than white on black). Any chance you could give us the option to chose the design or invert the colors?
    Thanks
    LNS
    Yes, of course. I write to Marcin (app designer) to project colors, and style to white background :)
  • Thank you for this beautiful and meaningful widget. I tend to agree with others, the old design was much more easier to read. I don't mind the battery reading on top, but I guess they are right, it does not make a lot of sense in a calendar widget.
    Today is the 19th of November, 2015. The date shows as 11.20.2015, with arrows on top and at the bottom. What does '20' stands for and what is the role of the these arrows there?
    Has this widget been removed from the Garmin Connect IQ store? I recently had my Fenix 3 stolen and replaced it with a new one but when I went to re-add this widget I can no longer find it in the app store.
  • Has this widget been removed from the Garmin Connect IQ store? I recently had my Fenix 3 stolen and replaced it with a new one but when I went to re-add this widget I can no longer find it in the app store.
    Wondering the same thing. The calender and watch faces have been removed for fenix 3
  • On the new design (epix clock) the battery meter does not look right, It is hidden in the upper area of the screen.
    Thanks for your work.
    After the last firmware update of my Fenix 3, it is removed from my watch and I can't find this widget in the App Store. Please fix it.
