Data Field: AppBuilder
By user request, this app lets you define your own data field, based on a simple math formula like cadence / 2.
If you want to get fancy, there's conditional expressions (like IF in Excel), functions for data analysis (like MIN and AVG), and the data field can also display the text of your choice. The resulting data can be (optionally) written to the activity FIT file.
With AppBuilder, you can implement almost any field that involves math, such as: calculating normalized power and saving the data to the FIT activity file, showing the average pace for even-numbered laps, or recording the amount of time you sprinted.
Full documentation and examples here:
http://ciq-appbuilder.blogspot.com/
AppBuilder 5:
Now with new features! AppBuilder 5 is a completely new app, so please check it out in the store if you are interested in any of the new features.
https://apps.garmin.com/en-US/apps/fd690281-9c22-4fee-a81e-3b7f39aa67c5
- Store up to four formulas per app. Switch between formulas directly on the watch, without using a phone or PC. With four clone apps, you can store up to 16 formulas total
- User variables. Allows for powerful formulas where information can be stored at one point, like the start of a lap, and used later. e.g. Lap elevation change
- Improved timeavg() options. Allows for simpler, more flexible normalized power function
- More functions and variables
4 clones of AppBuilder are available in the store, so you can have 2 formulas in the same activity
  • I ended up treating the lack of AppBuilder updates for the newer Garmins as an opportunity to teach myself how to write my own ConnectIQ apps.  No regrets.
  • Good afternoon.
    I love using AppBuilder CIQ fields for functionality not provided by Garmin (how is it STILL not possible to view distance based on time...). Would there be a possibility of seeing AppBuilder5+ for the Fenix 7 series? The 2 CIQ fields limitation is really bizzare, but we have to work with what Garmin gives us, and the + version handily deals with this limitation.
    Thank you for all your work!
    J
    PS: Please excuse my English, it isn'tmy 1st language.
  • Hi, flowstate.
    First of all, thanks for AppBuilder 5+ — it's an incredibly useful tool.
    I'd like to report a reproducible crash with the UserHRZone2Max variable (and possibly the whole UserHRZoneXMax family), and ask if you have any insight into what might be causing it.
    · DEVICE: Garmin Fenix 6 Pro Sapphyre
    · APP: AppBuilder 5+
    · CONTEXT: My HR zones are calculated automatically by Garmin based on % of lactate threshold (not % of max HR). I confirmed this by inspecting the FIT file's zones_target message, which shows hr_calc_type: 3. All 5 zones display real, non-null numeric values on the watch itself (Settings > User Profile > Heart Rate > Zones).
    · GOAL: I wanted to use UserHRZone2Max instead of a hardcoded BPM threshold so that my "time in effort zone" field would automatically stay accurate as my fitness improves and Garmin recalculates my zones over time — rather than having to manually update a fixed number every few weeks.
    · WHAT I TRIED (in order):
    1. This formula crashed the entire data screen (blank screen, small "IQ!" icon, no fields displayed at all):
      setv(6, if(hr gte UserHRZone2Max, 1, 0)); recordsummary(sum(getv(6))); record(getv(6))
    2. I suspected the casing might matter (lowercase "userHRZone2Max" vs. the documented "UserHRZone2Max"), so I corrected the casing and also added a null-guard, in case the zone value was somehow returning null despite being visible on the watch:
      setv(6, if(UserHRZone2Max eq null, 0, if(hr gte UserHRZone2Max, 1, 0))); recordsummary(sum(getv(6))); record(getv(6))
      Still crashed with the same "IQ!" icon.
    3. To isolate the problem, I tested with ONLY the bare variable reference, nothing else:
      UserHRZone2Max
      This alone also produced the "IQ!" crash.
    4. I confirmed via FIT file analysis (checking field_description messages) that when this field crashes, it never even gets registered as a developer field in the FIT — not even with a null value. It's a total failure from the very first second of the activity, not a gradual memory issue.
    5. As a workaround, I replaced the variable with a hardcoded BPM value (e.g., "hr gte 125") and it works perfectly — records correctly every second with no crash. This strongly suggests the issue is specific to reading the UserHRZone2Max variable itself under this zone configuration, not a general memory/complexity problem with the formula.
    · QUESTION: Have you seen this before with HR zones calculated via % lactate threshold rather than % max HR? Is there a known incompatibility, or something specific about how AppBuilder reads zone boundaries from the Connect IQ SDK that might behave differently depending on hr_calc_type? I'm happy to run any additional test formulas if that would help you reproduce/debug it — I have FIT files from each test above and can share them if useful.
    Thanks again for maintaining this app — happy to provide any more detail you might need.
    Best,
    joserogo
  • Hi,
    I've been building a set of 4 AppBuilder 5+ clones (2 screens active per activity, 6 fields each = 12 fields simultaneously) on a Fenix 6 Pro Sapphire, and ran into a crash pattern I can't fully explain, so I wanted to ask if this rings a bell.
    SUMMARY (without getting into formula specifics): One of my screens uses 6 fields, most of them built around comparing elapsed timer values with a "mod" operation to detect repeating time-based phases within a workout. With 5 of those 6 fields active (4 of them using "mod"), everything loads and records fine. As soon as I activate a 6th field that also uses "mod" (even a very simple one-line formula, functionally almost identical to ones already working), the whole screen fails to load (blank screen, small "IQ!" crash icon). If I simplify that same 6th field to avoid "mod" entirely (using a plain time-range comparison instead), everything loads fine with all 6 active.
    My other 3 screens (also 6 fields each, using more standard aggregate functions like avg/max/sum, setv/getv, prevn, etc., but none or at most one "mod") have never had this problem.
    QUESTION: Is there a known practical limit on how many "mod" (or similarly "heavier") operations can run simultaneously across the 6 fields of one screen, beyond the general memory guidance already in your docs? Or is this more likely to be a cumulative processing-time issue (too many fields each doing non-trivial per-second math) rather than something specific to "mod"? Any rule of thumb on what tends to push a screen over the edge on a Fenix 6 Pro Sapphire would be really helpful, so I stop guessing by trial and error.
    Thanks again.
    Best,
    joserogo
