Data Field: Surf Tracker
[FONT=Arial Black]Surf Tracker[/FONT]
Version 1.20
https://apps.garmin.com/en-US/apps/ded87d46-5477-4ca7-a247-847b896393e0
Track your surfing sessions in real time! This data field estimates the number of waves ridden using a speed and time threshold to mark the start and end of a wave ride.
Info shown (from left to right):
  • your total number of waves ridden and the total wave ride time (min:sec)
  • for your latest wave ride: wave ride time (seconds), maximum speed during the wave ride (km/hr or mph) and the distance covered (meters or yards)
  • the numbers in red show the maximum values for the wave ride time, speed and distance during the activity
  • For square watches, the bottom line shows the time of day and elapsed time of the activity. For round watches and the Vivo HR, the top line shows the time of day and the bottom line shows the elapsed time.
Notes:
1) This data field must be used in a 1-field data screen and should be set up before starting the activity. I use an Activity > Other > Paddle, but any activity with GPS ON should work. Open water swim will work but the GPS tracks are noisier since the sampling rate is lower, but it may be the better option for surfing when your arm is in and out of the water. Some activities smooth the speed data more than others and will give less accurate results (eg. a walking activity will not work as well as paddling or cycling). Vivoactive users try the Cycling activity, the Run activity will smooth the speed values to much to even out the Pace and this won't work well with the wave detection.
2) The summary stats and a speed plot are saved to Garmin Connect once the Activity is ended and saved:
3) This has been tested many times with standup paddle surfing. It has taken a while to get the thresholds working accurately. The detection thresholds can be changed using the Garmin Connect Mobile app (see https://forums.garmin.com/showthread.php?332843-How-to-App-Settings for help):
There are four settings to mark a wave ride based on speed, time and distance.
An event starts when the speed is >= 9 kph, it must last at least 6 seconds (above 9kph) and have a max speed of at least 13 kph to be counted. The event ends when it falls below 9kph. The min distance is set to 0m, but this can be changed to avoid false detections. These thresholds work well for standup paddle surfing, but try changing them and post your results. It should work for: standup paddle surfing, surfing, kayak surf, surf ski and maybe standup paddle downwinding.
Threshold ranges and defaults:
1) Start/stop threshold: default 9kph, range 5-50 kph
2) Time threshold: default 6s, range 2-60s
3) Max speed in event has to be >= 13kph, range 0-50kph
4) Min distance: default 0m (disabled), range 0-1000m
Typical values:
Standup paddle surfing: general setting for all waves
9kph, 6s, 13kph, 0m
Standup paddle downwinding (Hood River)
10kph, 10s, 12kph, 20m
4) The stats from each wave ride can be saved to a text file using the instructions at the bottom of the page (advanced users only, unsupported).
----------------- Planned Updates------------------
1) none hopefully
----------------- Version History ------------------
0.2 datafield now updates even when not visible.
0.3 added min distance to threshold test (now min 9km/hr for 5s and 15 m) to avoid paddling out/false wave counts, especially for SUP (eventually these values will be user selectable).
0.4 more tweaks after on-water tests (now min 9km/hr for 6sec), 19 waves and only 2 false readings and that was when I was chucked over the falls...
0.5 changed totdist and elapsed time to use the last good point of the event, instead of first one below the threshold, since when falling in it might take a while to get gps fix again and this will add to the waveride time. This should only decrease the wave ride time. The threshold test is now: >= 9km/hr for >= 6 sec and maxspeed >= 13 km/hr, redesign screen, add total wave ride time in min:sec
0.6 add fenix support.
0.7 bug fixed- crash when data field is in view and GPS just becomes active
0.8 D2Bravo, Epix and Vivoactive (separate app) support, compile using SDK 1.1.4. Latest numbers are green during an event (shows green if above speed threshold, even if below time threshold).
v0.9 new SDK 1.2.1, support for fr230/fr235
v0.95 new SDK, 2.1.3, support for Vivoactive HR
v1.0 added GCM settings for thresholds, changed distance calculation (should be shorter and more accurate), added 1 field Vivoactive support (got rid of the separate version)
v1.20 Garmin Connect summary stats and wave speed plot output
_________
** Advanced user only+unsupported method to save each wave ride to a text file on your device:
Place a *.TXT file in the /GARMIN/APPS/LOGS folder on your device, where * is the name of the .PRG file in the /GARMIN/APPS folder. Look for a file that is ~12 kilobytes. On my device it is 69SI5820.PRG, so I would create an empty file in /GARMIN/APPS/LOGS/69SI5820.TXT
To find out the filename, uninstall Surf Tracker, make a note of the *.PRG files in the /GARMIN/APPS folder, install Surf Tracker then note which PRG file is new.
Sample output format:
Wave# TimeofDay WaveRideTime(sec) WaveRideMaxSpeed(kph) WaveRideDistance(m)
1 07:26 20 28.8 113.4
2 07:28 13 27.6 76.8
3 07:33 21 30.2 122.2
Copy the file to your computer after a few sessions. I copy and paste the details into the notes section of the activity on Garmin Connect. The file will be appended to until it gets too big (10KB), then it will be overwritten. I had 3 days of sessions saved and it was only 1.8KB.
  • Some output to Garmin Connect in the latest version:
    Watch view:
    Garmin Connect summary stats:
    Garmin Connect: plot of speed for each of the 10 waves detected
    - it is just the speed plot with only the wave rides shown, so you can easily see the events
    - if you zoom in on an event you can see the location on the map area
    - an event isn't triggered until if reaches the min time threshold (in settings), so they tend to be truncated. But if you overlay the original speed you can see the entire segment
    So not perfect, but this might be all I can do for a data field. Much better then before and maybe we can get rid of the text file output...
    Give it a try.
    Former Member over 8 years ago
    Where do I find the screens referenced above
    Watch view:
    Give it a try.
    Hi - Where do I find the screen refrenced above with the graph and the data? I have looked on both my Garmin Connect mobile and online app
  • It "should" be on the bottom of the page on the Activity that you saved in both Garmin Connect (web) and Garmin Connect Mobile. You are the first one to provide feedback...thanks, some things to check:
    - are you using the latest v1.20 of Surf Tracker?
    - did you have the data field running when you did the Activity?
    - did you try uninstalling, rebooting, then re-installing Surf Tracker?
    - in Garmin Connect in the Activity, does it show the Surf Tracker logo underneath your Watch picture? It should show "Recorded with Surf Tracker" when you hover over the Surf Tracker image
    To check if it's working easily (without surfing):
    - just start the Activity (with Surf Tracker) and let it run for 20-30sec. Save it and let it upload with Garmin Connect. Then check online and the plot and summary stats should be there (0 waves, 0.00 total time etc)
    - or change the settings to 5kph/2sec/5kph/0m and start it and do some running around outside. When you start/stop it should detect "waves", then upload and check for the extra info
  • BWD1,
    I can't get the GC integration to work with my Fenix 3 for version 1.2. I've tried uninstalling the old version, restarting the watch then re-installing the new version. I've tried about 4 times but can't get it to work. I've tried with 'other' activity and SUP. I've also tried deleting the data field from the list in Garmin Express to try and delete it completely.
    I'm not sure if I've got the latest version but I assume it is since I'm just using the Connect IQ store to download and install. The surf tracker logo doesn't show up on GC under the watch either.
  • Thank you for trying it out. Please try the latest v1.30 and report back. You may have to uninstall, reboot, reinstall.
    You can just start an activity and let it run for 20secs then stop, save and upload to test it to see if you get any info on Garmin Connect or Mobile.
    If it still doesn't work then let me know what firmware and device. Create an empty file on your device:
    GARMIN\APPS\LOGS\CIQ_LOG.TXT
    Run the activity again start/stop/save then check for any contents in the file CIQ_LOG.TXT
    Thanks, I only have a 920XT for testing.
  • Sorry but that still doesn't work for me. I have the Fenix 3 with software 7.60. The log file is empty as well. I don't know if it is related, but each time I try to open garmin express after downloading the file then it crashes and has to be re-opened. After re-opening though it seems to work fine and I can install the surf tracker. I used the uninstall, reboot, reinstall method.
  • Hi David: that's no good...thanks for testing. I've run out of ideas. Hopefully someone else can comment if the output to GC works for them or not.
  • BWD1, Maybe I can sent you my FIT file and see if there is a difference between what your 920XT produces and what the F3 is producing? I don't know how it works but I'm guessing there is something that GC doesn't see from mine.
    BTW, it's an awesome job you've done so far!
  • Can you try the latest version 1.31? It was compiled with the latest SDK. It likely won't make a difference.
    Sure send me a FIT file and I can check if the values are being written (using PM or contact developer on the app page).
    Thanks,
    Dave
    Hello,
    Just surfed today. Installed the latest app yesterday and confirmed it's presence on the Fenix 3 HR.
    Used SUP as the activity and now looking for some data in Garmin Connect area.
    Any tips or is the Fenix not supported? New watch btw with latest OS.
