DIY Data Field
Application is still pending to be approved, topic is created to be used as a communication hub during and after public beta test.
Do/Design It Yourself Data Field.
Disclaimer:
Application has hundreds of use-cases due to fully user-configurable setup, therefore it is prone to bugs. This project is not sponsored and I'm the only developer working on it in my own free time. Although I'd gladly accept reasonable criticism and improvement suggestions, I do not guarantee that bugs will be fixed and new features added in a timely manner/at all. If this approach is not acceptable for you, then, please, do not leave bad reviews just because I didn't resolve your specific case. Thanks for understanding.
Preface:
There's a lot of things custom activity recorders can do, which native Garmin apps cannot, but sometimes there's no need to invent a bicycle if there's one already itching for a ride. Some capabilities like local watch personal records, structured workouts information and advanced running dynamics will most certainly never be exposed to ConnectIQ API layer, therefore it's sometimes more efficient to use native software, but no one prevents us to use it with a twist. The main idea of this data-field type application is to give user a tool to design his own data field layout in WYSIWYG manner. The web application makes that possible providing cross-platform compatibility at the same time the only requirement being the HTML5 compatible browser. This app is not considered to be an ultimate DF which "replaces them all" as there's always something new and intriguing, which developer may envision, but I hope that this data field will help new and existing users to explore the Garmin ConnectIQ capabilities providing some unique features, which I didn't encounter in existing apps.
First things first: there's a web application, which allows to design data field layout and produces configuration string as a result. This configuration string can only be delivered to data field using standard settings means i.e. you will need either Garmin Express installed on compatible PC or Garmin Connect Mobile on your mobile device. Web app uses HTML5 local storage, changes are saved after each user action, therefore it's safe to leave your work half done and proceed from the same point sometime later. I do not own hardware to test with Apple devices, therefore any problems in that department can be explored and fixed only by sending me detailed explanations and, of course, the configuration string itself. Current version with the default layout setup was tested for several weeks in simulator and for several of my personal runs proving to be rather stable to go live, but of course there's no guarantee that this app will function without hitches on your specific device. Currently, I do not have a reliable hosting for my personal web apps, therefore data field designer will reside on Google Apps Engine servers using free account bandwidth/limitations (as there are almost no server-side computations, I think this will suffice for a while) at least if/until it'll become popular enough for the users to complain about page availability. Current implementation with the default layout setup works on the edge of stability and there was also a price to pay during watch code optimization, which lead to efficient but very unreadable code. This means that for older devices there may be no improvements, only bug fixes. But for modern devices like Forerunner735XT and on we still have additional 10kb of available memory, which can be used for new logic like new data values and/or additional app parameters (e.g. waypoints). Sometimes network latency and/or Google servers accessibility seems to impact resources load time and wrong font may be displayed first time the web app is started, to fix this simply press F5 (refresh page) in browser.
Current settings are 4 lines for definition itself (these should be copy/pasted without changes directly from web app), Target Pace for pacemaker values (should be entered as string in <min>:<sec> format, e.g. "5:40" as in min/km) and Milestones, which are just fixed distances comma separated list, they are expressed in kilometers and may contain fractional values using dot delimiter (e.g. 0.5,1,1.5, etc). It'necessary to enter values in kilometers, but they will be converted before display depending on watch settings.
Default setup is considered to be a "component showcase" and consists of basic building blocks:
- Data values, which are simply text representation of corresponding activity information bits like time or speed, for data values it's possible to change screen coordinates, font, color, number of samples to smooth the value over specified amount of seconds and add optional outline for data to become more readable or dynamically colored on less contrast backgrounds; if text font is selected, then it's also possible to append data value with custom text, e.g. create label with value for another data block;
- Data graphs, these are just rolling data value charts, which represent one selected data value over a set period of time, minimum and maximum graph values are adjusted automatically, number of samples is calculated automatically based on width of graph area and graph bar, all of the other options are similar to data values;
- Graphics elements, these are basic graphical primitives, which allow to customize the layout, add visibility to some values etc; parameters for these elements are mostly self explanatory except for two specific elements of type Arc. These may not only serve as a static view elements, but also can be used to represent a dynamic data value in a manner of a progress bar. For this to happen you need to tick the "Variable" option and select base Data value (currently there's only a limited selection, but this may be a subject to change) accompanied by min and max initial values, these range values are indeed initial as when the underlying data value falls outside of this range, then range is adjusted automatically. For example in bundled layout this feature is used to display the progress to the next kilometer: Elapsed distance is selected as a base value, initial range is specified as 0 to 100 (in this case 100 means 1000m, as the distance values are displayed as 00.00), which means that this arc will grow from start angle to the maximum width angle as the elapsed distance increases during activity acting as a progress bar to the next kilometer. When elapsed distance will become greater than 1000 meters, then ranges will be readjusted using the same range difference as before, in this case minimum value will become 1000m while maximum one will increase to 2000m. Here's a little demo of what you can make using variable value arc (this config is created for semi-round devices, copy/paste this configuration string into import window of web app).
AGUAJA[HIWaVFAJNATXDEAODZQVELEUA[HIWaVFAODU]`DEAOEOQVEVE_A[HIWaVFAABG`[DEAOFDQWE`FHA[HIWaVFAABHGRDEAOF[QWFIFRA[HIWaVFAJNA\ODEAOGQQVFSF\A[HIWaVFAOE]CPCWAODZTMELF\A[HIWaVFAAAAAACWAPDWTMELF\ASADILDAPOE]CPFEABAVDVENQAPQAAAFDJCFACB
Selected element options can be adjusted using the properties panel to the right of the designer canvas. In addition to pixel-by-pixel adjustments, designer canvas allows to drag currently selected element. To drag data value it's not necessary to start drag at any specific point, but for graphs and graphical elements the drag point will be determined based on mouse pointer coordinates: e.g. to resize graph area or rectangle click and drag somewhere around the lower right corner, to adjust the radius of circles and direction arrow start drag outside of the outer radius, to change coordinates - click somewhere near the circle center. For the arcs it's currently possible to change start angle and arc width by activating drag-and-drop near the corresponding arc vertex. Touch support for mobile devices is implemented.
There are still some limitations like direction arrow points only to north or some data values available only on high-end devices like power are not yet implemented etc, but as I already mentioned above, this app is subject to improve especially for the newer devices, where there's a lot of memory available even for the data field type of app. The web app is also meant to be improved especially in a direction to provide the nearest possible WYSIWYG snapshot of what you'll actually see on device, but there are also some limitations like, for example, font, which is used as numeric font in the latest Fenix5/FR935 models is not and won't be publicly available (confirmed by Garmin officials explicitly) and I used nearest lookalike, therefore there still may be some couple of pixel differences here and there between device and web app. For these kinds of problems I can only test and fix using the user-provided layouts in specific device simulator as I'm a simple FR230 owner for real testing and I'm afraid this won't change in the nearest year unless generous users will help me to upgrade.
Web app may eventually become mobile application based on the user feedback (but not for the Apple devices, Android only).
  • Hello, great application. this exactly justify why I bought FR935.
    A question. It seems like "Current Altitude" is shown in Feet even though I setup the device in metric. Can I somehow multiply 0.3048 to show it in Meter?
    Edited.
    After a night, it seems in meter now. Thank you!
  • Excellent job! I downloaded the eclipse app to start learning how to make my datafield until I saw your job.
    let me give you a challenge: what about a analog meter graph? I saw the analog datafield on ciq and I like it, but it still misses HR.
  • Hi,
    Congrutations for this wonderful app.
    I'm experiencing some lag with timer and lap time display. From time to time, the display "jumps" 1 or 2 seconds, displaying 10:03 just after 10:01 for example. The time itself is correct, it seems that there's a delay in the global process of diplay. This occurs with some sophisticated screens I've designed, but it also occurs with the default parameters provided with the app (the first 8 to 9 seconds are displayed correctly, than the following second is not displayed...the app lags), then 8 to 9 seconds are displayed correctly, then 1 second is omitted and so on.
    I'm using Garmin Edge 520.
    Is a known issue ? How can I get rid of it ?
    Thank you
  • Finally finish my ideal datafield... however since there is no "dial" options like analog meter, I used an arc over another arc with the same dynamic value as speed, but with arc width a point or 2 shorter, in order to give the effect of the "dial". However the refresh speed is so slow that my "dial" show up some times only and others is hidden. So I took off the overlapping arc leaving only one arc for speed.
    This is my creation...
    upper arc for speed, middle arc for cadence, bottom section the elapsed time and distance, and battery juice.... also as a background I have the HR zone colors to visualize on which HR zone I am... (HR number is on top)
    AJDA`AQHJI\FAHOE]CPDVAQHJI\FAHQACQDDDASAG^W]ACOE]CPGCABASAG\[YACAAAAAGCABASHIPTPAAABG`[AJAMASHITLRAAABG`[AFAFASAHTKWA[ABG`[AAABATAIMVPCDABG`[AAAB%AZAG\[KCDAAAAAACABCadenceASAG\Y^APAAAAAGCADAUAEO[KCDAAAAAACAB40AUAG\YVCDAAAAAACAB80AVAJ[TACDAAAAAAAAB120AWK[aLYACOE]CPBZAIVQFRA[HJI\UFAAAAHYBZAHVPVPBHDVAUAJH\PCDAAAAAACABKmASAIOQOAMAAAAAFAABASAG\W[AVOE]CPAKABAWHJI\FACAAAAADMASE\GYAWHJI\FACOE]CPDNARE]GWA\HJI\FE\UC]BGDNARE]WWPFEEMASAI\RKAJAAAAAGAABAWAI^ODCDAAAAAAEABKm/hAUAD]^OCDAAAAAACAB20AUAG]E^CDAAAAAACAB25AUABTXCCDAAAAAACAB15AUHD[KPABOE]CPGTABEZAUAARAWCDAAAAAACAB10AUAJ[PYCDAAAAAACAB30AUAMCYHCDAAAAAACAB35AUANFRECDAAAAAACAB40ABHODA^SABCODU]`AAUAB[`GAAPABHGRAAAJOHXV
  • Still playing with this amazing DIY Datafield... Thanks! Thanks! Thanks!.
    this is my latest improvement on my design. I am adding max speed and average speed, as well as the time of the day. You need to try it since the picture does not show the big picture.
    AKFBBAQHJI\FAHOE]CPDVAQHJI\FAHUSL[[DDASAG^WSACOE]CPGCABASAG\[OACAAAAAGCABASHIPTPAAABG`[AJAMASHITLRAAABG`[AFAFASAHTKWA[ABG`[AAABATAIMVPCDABG`[AAAB%AVAG\ZaCDAAAAAACABCADASAG\Y^APAAAAAGCADAUAEO[KCDAAAAAACAB40AUAG\YVCDAAAAAACAB80AVAJ[TACDAAAAAAAAB120AWK[aLYACOEH]LBZAIVQFRA[HJI\UFAAAAHYBZAHVPVPBHDVAUAJH\PCDAAAAAACABKmASAIOQGAMAAAAAFAABASAG\WYAVOE]CPBKABAWHJI\FACAAAAADMASE\GYAWHJI\FACOE]CPDNARE]GWA\HJI\FE^JOHXVDNARE]WWPFEEMA\HJI\FE\ABHGRDNARE]WWPFEEMA\HJI\FE]EXUL\DCAFE]WWPFEEMASAI\RKAJAAAAAGAABAWAI^ODCDAAAAAAEABKm/hAUAD]^OCDAAAAAACAB20AUAG]E^CDAAAAAACAB25AUABTXCCDAAAAAACAB15AUAARAWCDAAAAAACAB10AUAJ[PYCDAAAAAACAB30AUAMCYHCDAAAAAACAB35AUANFRECDAAAAAACAB40AWHJJE^ACAAAAAKCABTIBBASAG\]MABOE]CPAKABAFCODA^SAEXODU]`AELABG`[ADaABHGRADUJOHXVAAAOE]CPcommunity.garmin.com/.../1298903.png
  • Hi,
    I really love the piece of work you did. In case you are interested, my fields I made so far look like this:
    AL\BGAQHJI\FAHOE]CPDVASHEXYHAAAAAAAE]A`ASHEXPCAAAAAAAE]A^ASHCOEAAAAAAAAHJBZASAGYM]ABJOHXVFCABAUHCVVHABAAAAAHFABCYAUHCVVIABJOHXVHFABCZAUHCVXAABJOHXVHFABERAUHCVXBABAAAAAHFABESAUHEXPBABAAAAAGCABGMAUHGNXNABEXUL\CEABCYAUHMDZPABEXUL\FFABCYAUHGAT\ABJOHXVB_ABERAUHMQaYABJOHXVFMABEQAUHJI]CABEXUL\DVABGMASHDYKTAAQACQDBNATAUADN]QCDOE]CPAAABHRASACJI_AVQACQDFCACASHGPTQAAOE]CPCaAUAWAG\XECDAAAAAACABPaceASAG\XTAGAAAAAGCAFASHMFVSAAQABZVBNATAVAJaEPCDOE]CPAEABCadASALPBWAPVK^G^FCAFAWAC^a\CDJOHXVAAABø HRASAB\JFAWQACQDFCABAYAG\ZACDJOHXVACABø PaceASAG\ZKAHABG`[GCAFAXAKT^ACDJOHXVAEABø CadASALaA`AQVK^HCFCAFA[AJNPZCDAAAAAACABDistanceASAJ[T_AMAAAAAGCABAWADa\ACDAAAAAACABTimeASADNaKACAAAAAFCABAQHKJZJAHQAF_PAFAWHKJZJACQAF_PAKADRMCYAWHKJZJACQAF_PAKADEDCYASHIARYAAQADCVASAJASHJBM^AAQADCVADAFAFHJNA\OAE_ABHGRAEYABG`[AESODU]`AAAJNATX
    and
    APFA`AQHJI\FAHOE]CPDVASHEXYHAAAAAAAE]A`ASHEXPIAAAAAAAE]A^ASHCOEAAAAAAAAHJBZASAGYM]ABJOHXVFCABAUHCVVHABAAAAAHFABCYAUHCVVIABJOHXVHFABCZAUHCVXAABJOHXVHFABERAUHCVXBABAAAAAHFABESAUHEXPHABAAAAAGCABGSAUHGAT\ABJOHXVB_ABERAUHMQaYABJOHXVFMABEQAUHJ\VWABEXUL\D`ABGSAVDR\KGASOEH]LF`B\ACBAUAB\IWCDJOHXVACABUpASAB\JFATJNATXFCAFA[AG\ZACDJOHXVACABAltitudeASAG\ZKASOE]CPGCAFAWAL_ENCDJOHXVACABDownASALaA`AUABG`[FCAFAWAJTEECDAAAAAACABDistASAKE^MAMAAAAAGCABAWAEUQ]CDAAAAAACABTimeASAD^AOACAAAAAFCABASAD^BGADEXUL\FCABAQHKNRTAHQAF_PAFAWHKNRTACQAF_PAKADRMCYAWHKNRTACQAF_PAKADEDCYASHIAR_AAQADCVASAJASHJBNCAAQADCVADAFAQHL^H]CEAB[`GAJ
    I came across several things I'm not sure I use or understand right.
    I use average cadence field. How is it calculated? It seems to me, that this field is calculated from total workout time including stops (elapsed time). I think the calculation should exclude stops. Or am I mistaken?
    I know from reading the forum that currently it is not possible to implement equation parsing. I think it would be beneficial to add some more data values using simple equations. I think I would really appreciate "stopped time" (elapsed time-timer time), "altitude difference" (total ascent-total descent), "pace difference" (current pace-avg. pace). It would give me great info about the trip, such as how much is still left to climb or descent (if you start and finish at the same location) or how much time we spent on breaks. And while running or cycling, I could visualise by adding dynamic color whether I'm above average pace or below.
    I one field I also used elevation graph generated from elevation datafield. Is it possible to influence the sample rate (the sample time span)? At the moment, the graph updates every second, so the time span is very small. Ideally the graph could adjust scale to fit to the assigned display area, but I don't know if it is possible. If not, it would be great if I could set update time.
  • Hi,
    and
  • This does look indeed as the solution to end all data fields available in the CIQ store - very exciting.
    On caveat for me at the moment is, that it seems to be running focused and what I am really looking for is a bike focused data field for that second leg in a triathlon. All the basic (3s average) and advanced (NP, IF) power fields become immensely important and they are currently not available. Is it particularly hard to include those (are they provided by Garmin's API) or is it something you'd rather not work on?
    Former Member over 7 years ago
    Hi all,
    I was not paying much attention to this thread for a couple of months, can't say I'm back, but I'' analyze the thread for suggestions and will try to implement some of them, although most of the new features will be available to the most capable devices first (Edges, Fenix5x and Descent MK1 which provide 128kb per data field).
    I've listed values provided by Garmin API here and, as you can see, almost all of them are implemented, other than that - developer has to implement everything himself. There are already several values which I calculate using different methods that Garmin native ones with a comparable results. 3s average is possible for every value, just change the number of samples to 3, NP is available, but I do not know exactly what is IF, although I remember one user sent some formulas of cycling specific values.
    Currently I'm trying to implement simple expressions because this will resolve a lot of request, I'll consider other specific values when this work is complete.
  • Hi all,
    Interesting list - thank you for pointing me towards it. This explains why there are tons of running-specific fields and very few cycling specific data fields since it appears that most of the - albeit simple - math has to be done by the app itself (e.g. IF = Intensity Factor = Normalized Power / FTP, it basically gives you a very easy way to gauge how far you've pushed yourself with regards to your threshold).
    Anyways - keep up the good work, looking forward to all the good things that will come from your data field.
