DIY Data Field
Application is still pending to be approved, topic is created to be used as a communication hub during and after public beta test.
Do/Design It Yourself Data Field.
Disclaimer:
Application has hundreds of use-cases due to fully user-configurable setup, therefore it is prone to bugs. This project is not sponsored and I'm the only developer working on it in my own free time. Although I'd gladly accept reasonable criticism and improvement suggestions, I do not guarantee that bugs will be fixed and new features added in a timely manner/at all. If this approach is not acceptable for you, then, please, do not leave bad reviews just because I didn't resolve your specific case. Thanks for understanding.
Preface:
There's a lot of things custom activity recorders can do, which native Garmin apps cannot, but sometimes there's no need to invent a bicycle if there's one already itching for a ride. Some capabilities like local watch personal records, structured workouts information and advanced running dynamics will most certainly never be exposed to ConnectIQ API layer, therefore it's sometimes more efficient to use native software, but no one prevents us to use it with a twist. The main idea of this data-field type application is to give user a tool to design his own data field layout in WYSIWYG manner. The web application makes that possible providing cross-platform compatibility at the same time the only requirement being the HTML5 compatible browser. This app is not considered to be an ultimate DF which "replaces them all" as there's always something new and intriguing, which developer may envision, but I hope that this data field will help new and existing users to explore the Garmin ConnectIQ capabilities providing some unique features, which I didn't encounter in existing apps.
First things first: there's a web application, which allows to design data field layout and produces configuration string as a result. This configuration string can only be delivered to data field using standard settings means i.e. you will need either Garmin Express installed on compatible PC or Garmin Connect Mobile on your mobile device. Web app uses HTML5 local storage, changes are saved after each user action, therefore it's safe to leave your work half done and proceed from the same point sometime later. I do not own hardware to test with Apple devices, therefore any problems in that department can be explored and fixed only by sending me detailed explanations and, of course, the configuration string itself. Current version with the default layout setup was tested for several weeks in simulator and for several of my personal runs proving to be rather stable to go live, but of course there's no guarantee that this app will function without hitches on your specific device. Currently, I do not have a reliable hosting for my personal web apps, therefore data field designer will reside on Google Apps Engine servers using free account bandwidth/limitations (as there are almost no server-side computations, I think this will suffice for a while) at least if/until it'll become popular enough for the users to complain about page availability. Current implementation with the default layout setup works on the edge of stability and there was also a price to pay during watch code optimization, which lead to efficient but very unreadable code. This means that for older devices there may be no improvements, only bug fixes. But for modern devices like Forerunner735XT and on we still have additional 10kb of available memory, which can be used for new logic like new data values and/or additional app parameters (e.g. waypoints). Sometimes network latency and/or Google servers accessibility seems to impact resources load time and wrong font may be displayed first time the web app is started, to fix this simply press F5 (refresh page) in browser.
Current settings are 4 lines for definition itself (these should be copy/pasted without changes directly from web app), Target Pace for pacemaker values (should be entered as string in <min>:<sec> format, e.g. "5:40" as in min/km) and Milestones, which are just fixed distances comma separated list, they are expressed in kilometers and may contain fractional values using dot delimiter (e.g. 0.5,1,1.5, etc). It'necessary to enter values in kilometers, but they will be converted before display depending on watch settings.
Default setup is considered to be a "component showcase" and consists of basic building blocks:
- Data values, which are simply text representation of corresponding activity information bits like time or speed, for data values it's possible to change screen coordinates, font, color, number of samples to smooth the value over specified amount of seconds and add optional outline for data to become more readable or dynamically colored on less contrast backgrounds; if text font is selected, then it's also possible to append data value with custom text, e.g. create label with value for another data block;
- Data graphs, these are just rolling data value charts, which represent one selected data value over a set period of time, minimum and maximum graph values are adjusted automatically, number of samples is calculated automatically based on width of graph area and graph bar, all of the other options are similar to data values;
- Graphics elements, these are basic graphical primitives, which allow to customize the layout, add visibility to some values etc; parameters for these elements are mostly self explanatory except for two specific elements of type Arc. These may not only serve as a static view elements, but also can be used to represent a dynamic data value in a manner of a progress bar. For this to happen you need to tick the "Variable" option and select base Data value (currently there's only a limited selection, but this may be a subject to change) accompanied by min and max initial values, these range values are indeed initial as when the underlying data value falls outside of this range, then range is adjusted automatically. For example in bundled layout this feature is used to display the progress to the next kilometer: Elapsed distance is selected as a base value, initial range is specified as 0 to 100 (in this case 100 means 1000m, as the distance values are displayed as 00.00), which means that this arc will grow from start angle to the maximum width angle as the elapsed distance increases during activity acting as a progress bar to the next kilometer. When elapsed distance will become greater than 1000 meters, then ranges will be readjusted using the same range difference as before, in this case minimum value will become 1000m while maximum one will increase to 2000m. Here's a little demo of what you can make using variable value arc (this config is created for semi-round devices, copy/paste this configuration string into import window of web app).
AGUAJA[HIWaVFAJNATXDEAODZQVELEUA[HIWaVFAODU]`DEAOEOQVEVE_A[HIWaVFAABG`[DEAOFDQWE`FHA[HIWaVFAABHGRDEAOF[QWFIFRA[HIWaVFAJNA\ODEAOGQQVFSF\A[HIWaVFAOE]CPCWAODZTMELF\A[HIWaVFAAAAAACWAPDWTMELF\ASADILDAPOE]CPFEABAVDVENQAPQAAAFDJCFACB
Selected element options can be adjusted using the properties panel to the right of the designer canvas. In addition to pixel-by-pixel adjustments, designer canvas allows to drag currently selected element. To drag data value it's not necessary to start drag at any specific point, but for graphs and graphical elements the drag point will be determined based on mouse pointer coordinates: e.g. to resize graph area or rectangle click and drag somewhere around the lower right corner, to adjust the radius of circles and direction arrow start drag outside of the outer radius, to change coordinates - click somewhere near the circle center. For the arcs it's currently possible to change start angle and arc width by activating drag-and-drop near the corresponding arc vertex. Touch support for mobile devices is implemented.
There are still some limitations like direction arrow points only to north or some data values available only on high-end devices like power are not yet implemented etc, but as I already mentioned above, this app is subject to improve especially for the newer devices, where there's a lot of memory available even for the data field type of app. The web app is also meant to be improved especially in a direction to provide the nearest possible WYSIWYG snapshot of what you'll actually see on device, but there are also some limitations like, for example, font, which is used as numeric font in the latest Fenix5/FR935 models is not and won't be publicly available (confirmed by Garmin officials explicitly) and I used nearest lookalike, therefore there still may be some couple of pixel differences here and there between device and web app. For these kinds of problems I can only test and fix using the user-provided layouts in specific device simulator as I'm a simple FR230 owner for real testing and I'm afraid this won't change in the nearest year unless generous users will help me to upgrade.
Web app may eventually become mobile application based on the user feedback (but not for the Apple devices, Android only).
  • On 1030 I have it on "A" - but have not used "lap" for a while.
    On 1000 I have tested it on "B"!
    Now I will test it with "DIY-A".
    Just a few minutes...
    Edit:
    Just checked on both devices 1000 and 1030 with both DIY-programs:
    Behaviour is on both devices as you described it:
    DIY-B on both devices works flawlessly
    DIY-A on both devices the new lap-time do not start by zero but timer keeps on counting.
    I have both programs (DIY-A and B) on latest software.
    INFO for easuvorov:
    It is not the "old issue" we had before, where lap counter and intern lap-value were not resettet after ending an activity. This still works!
    The issue now is, that (only) with program "A" a new lap (during an activity) does not set the timer to zero but the timer keeps on counting.
    Same issue with "Elapsed distance" - keeps counting too!
    (lap-counter works fine!)
    Odometer now works fine, too - on both devices (1000, 1030).
  • Good info to confirm I'm not doing something silly. Thanks
    I seem to remember easuvorov posting somewhere back in this post that his little one was unwell. It's not a biggy though as I can use DIY B. I'm sure he'll get round to sorting it at some point
  • I just did a ride with both devices, Edge 1000 and Edge 1030:
    With DIY-A now:
    -Traing Effect digits: check!
    -Lap-Timer and -Distance reset: check!
    -Odometer set, increase and save: check!
    Many thanks to easurvorov!
    For those who like to implement odometer to their DIY-A design - you should know:
    To set the odometer starting value via Garmin Express or Garmin Connect Mobile (Android only) works only one time - the first time.
    Because:
    When this value is stored the first time, a new file is ceated on your device: \garmin\Apps\DATA\123XYZ.STR
    From that moment on this DATA-file will keep your odometer-values up to date and the stored value via GE or GCM has no effect anymore.
    To set a new odometer value via GE or GCM you have to delete the DATA-STR file first!
    (@ easuvorov: If my comment does not match to the way you have designed it - please let us know!)
  • Hello Everybody
    can anyone help me?
    I managed to create a datafield (for hill climbing)
    When I click on the circular arrows I can chose either "Garmin express" or "local".
    I understood that I have to copy the string but which one??? (Garmin express or local?)
    Then I understood that I have to paste the string into "Garmin Express"? But I do not find a field where I can paste in ?
    I would be thankful for your help
    kind regards
    Joe
  • First of all you need to install the DIY-app on your device.
    Do it by GE (Garmin Express) or GCM (Garmin Connect Mobile).
    When you have completed your DIY-project with DIY-designer, you are ready to export your project:
    2 options of showing the definition-string:
    LOCAL:
    This option is for saving your project locally and import a stored project.
    Although your project is stored in the cache of your browser, it is useful to store in a file, too.
    Copy and paste the "local" def-string in a textfile (using any editor).
    To re-import the project, copy and paste it from the textfile into the designer's local-import-window and press import.
    GARMIN EXPRESS:
    This option is for transferring your project to your device.
    Using this option you will see up to 4 strings.
    Now plug in your device to your PC and start Garmin Express.
    From the home-screen chose your device.
    Press the button in section Connect IQ | Apps.
    Now you see all IQ-apps installed on your device.
    Press the 3-dots-button of DIY Data Field.
    A window opens with 4 input-fields for the definition strings.
    Make all 4 strings empty - delete the entries shown!
    Now copy and paste one def-string by another from designer-tool to GE.
    When all strings (maby only one with small projects) are copied to GE, press "Save".
    If a green message appears (successfully saved), you can close GE, unplug your device safetly and let the device boot.
    After reboot of your device you can set the DIY-datafield on your device.
  • Currently HR zone colors are hard-coded in the web/watch app to match the Garmin colors, but zone range values are checked at run time with user profile definition for "Running" sport type. You may want to check your heart rate zones definitions both on watch and in Garmin Connect to make sure these values are matching.
    Hi Eugene - the HR zone range values are not being read from user profile, it is using the hard coded "Heart Rate Zones" from the web app. Should I define my own colour set to match my Garmin HR zone profile, or is this a bug that has crept in?
    Former Member over 7 years ago
    Well, as you can imagine, I cannot read your user profile values in a web-app, therefore the values presented for built-in dynamic color set are from my own profile just to show how things work, but if you will use this dynamic color set, then range values will be determined at run time from your user profile returned by connectIQ API. But you'll have to enter your own specific range values if you wish to redefine colors in a new custom color set.
  • Well, as you can imagine, I cannot read your user profile values in a web-app, therefore the values presented for built-in dynamic color set are from my own profile just to show how things work, but if you will use this dynamic color set, then range values will be determined at run time from your user profile returned by connectIQ API. But you'll have to enter your own specific range values if you wish to redefine colors in a new custom color set.
    No, I understand the web app can't read my profile, but also the data field is not reading my user profile at run time, I memorised the default web-app "example" values, and the watch seems to be using those at run time.
    Also this morning I notice the heart rate zone value is incorrect, in my zone 1 it was reading 3.x, and then later it was up to 4.x when I was running easily.
    Let me test again over the weekend and I will report back.
    Strange things as it seemed to be working good and I didn't change that code for quite a while. I'll try to investigate with my own values but if you encounter a bug then it would be easier if you send me test-case explanation accompanied by your fit file.
  • Apologies, it seems my heart rate profile had not synced to the watch correctly. So let me test again, should be ok now.
    I did notice that when the HR is less than the Z1 lower limit, Garmin's HR zone field says 0.x whereas DIY says 1.x. Then when HR rises and is within Z1, both Garmin zone field and are the same, i.e. 1.x.
