DIY Data Field
Application is still pending to be approved, topic is created to be used as a communication hub during and after public beta test.
Do/Design It Yourself Data Field.
Disclaimer:
Application has hundreds of use-cases due to fully user-configurable setup, therefore it is prone to bugs. This project is not sponsored and I'm the only developer working on it in my own free time. Although I'd gladly accept reasonable criticism and improvement suggestions, I do not guarantee that bugs will be fixed and new features added in a timely manner/at all. If this approach is not acceptable for you, then, please, do not leave bad reviews just because I didn't resolve your specific case. Thanks for understanding.
Preface:
There's a lot of things custom activity recorders can do, which native Garmin apps cannot, but sometimes there's no need to invent a bicycle if there's one already itching for a ride. Some capabilities like local watch personal records, structured workouts information and advanced running dynamics will most certainly never be exposed to ConnectIQ API layer, therefore it's sometimes more efficient to use native software, but no one prevents us to use it with a twist. The main idea of this data-field type application is to give user a tool to design his own data field layout in WYSIWYG manner. The web application makes that possible providing cross-platform compatibility at the same time the only requirement being the HTML5 compatible browser. This app is not considered to be an ultimate DF which "replaces them all" as there's always something new and intriguing, which developer may envision, but I hope that this data field will help new and existing users to explore the Garmin ConnectIQ capabilities providing some unique features, which I didn't encounter in existing apps.
First things first: there's a web application, which allows to design data field layout and produces configuration string as a result. This configuration string can only be delivered to data field using standard settings means i.e. you will need either Garmin Express installed on compatible PC or Garmin Connect Mobile on your mobile device. Web app uses HTML5 local storage, changes are saved after each user action, therefore it's safe to leave your work half done and proceed from the same point sometime later. I do not own hardware to test with Apple devices, therefore any problems in that department can be explored and fixed only by sending me detailed explanations and, of course, the configuration string itself. Current version with the default layout setup was tested for several weeks in simulator and for several of my personal runs proving to be rather stable to go live, but of course there's no guarantee that this app will function without hitches on your specific device. Currently, I do not have a reliable hosting for my personal web apps, therefore data field designer will reside on Google Apps Engine servers using free account bandwidth/limitations (as there are almost no server-side computations, I think this will suffice for a while) at least if/until it'll become popular enough for the users to complain about page availability. Current implementation with the default layout setup works on the edge of stability and there was also a price to pay during watch code optimization, which lead to efficient but very unreadable code. This means that for older devices there may be no improvements, only bug fixes. But for modern devices like Forerunner735XT and on we still have additional 10kb of available memory, which can be used for new logic like new data values and/or additional app parameters (e.g. waypoints). Sometimes network latency and/or Google servers accessibility seems to impact resources load time and wrong font may be displayed first time the web app is started, to fix this simply press F5 (refresh page) in browser.
Current settings are 4 lines for definition itself (these should be copy/pasted without changes directly from web app), Target Pace for pacemaker values (should be entered as string in <min>:<sec> format, e.g. "5:40" as in min/km) and Milestones, which are just fixed distances comma separated list, they are expressed in kilometers and may contain fractional values using dot delimiter (e.g. 0.5,1,1.5, etc). It'necessary to enter values in kilometers, but they will be converted before display depending on watch settings.
Default setup is considered to be a "component showcase" and consists of basic building blocks:
- Data values, which are simply text representation of corresponding activity information bits like time or speed, for data values it's possible to change screen coordinates, font, color, number of samples to smooth the value over specified amount of seconds and add optional outline for data to become more readable or dynamically colored on less contrast backgrounds; if text font is selected, then it's also possible to append data value with custom text, e.g. create label with value for another data block;
- Data graphs, these are just rolling data value charts, which represent one selected data value over a set period of time, minimum and maximum graph values are adjusted automatically, number of samples is calculated automatically based on width of graph area and graph bar, all of the other options are similar to data values;
- Graphics elements, these are basic graphical primitives, which allow to customize the layout, add visibility to some values etc; parameters for these elements are mostly self explanatory except for two specific elements of type Arc. These may not only serve as a static view elements, but also can be used to represent a dynamic data value in a manner of a progress bar. For this to happen you need to tick the "Variable" option and select base Data value (currently there's only a limited selection, but this may be a subject to change) accompanied by min and max initial values, these range values are indeed initial as when the underlying data value falls outside of this range, then range is adjusted automatically. For example in bundled layout this feature is used to display the progress to the next kilometer: Elapsed distance is selected as a base value, initial range is specified as 0 to 100 (in this case 100 means 1000m, as the distance values are displayed as 00.00), which means that this arc will grow from start angle to the maximum width angle as the elapsed distance increases during activity acting as a progress bar to the next kilometer. When elapsed distance will become greater than 1000 meters, then ranges will be readjusted using the same range difference as before, in this case minimum value will become 1000m while maximum one will increase to 2000m. Here's a little demo of what you can make using variable value arc (this config is created for semi-round devices, copy/paste this configuration string into import window of web app).
AGUAJA[HIWaVFAJNATXDEAODZQVELEUA[HIWaVFAODU]`DEAOEOQVEVE_A[HIWaVFAABG`[DEAOFDQWE`FHA[HIWaVFAABHGRDEAOF[QWFIFRA[HIWaVFAJNA\ODEAOGQQVFSF\A[HIWaVFAOE]CPCWAODZTMELF\A[HIWaVFAAAAAACWAPDWTMELF\ASADILDAPOE]CPFEABAVDVENQAPQAAAFDJCFACB
Selected element options can be adjusted using the properties panel to the right of the designer canvas. In addition to pixel-by-pixel adjustments, designer canvas allows to drag currently selected element. To drag data value it's not necessary to start drag at any specific point, but for graphs and graphical elements the drag point will be determined based on mouse pointer coordinates: e.g. to resize graph area or rectangle click and drag somewhere around the lower right corner, to adjust the radius of circles and direction arrow start drag outside of the outer radius, to change coordinates - click somewhere near the circle center. For the arcs it's currently possible to change start angle and arc width by activating drag-and-drop near the corresponding arc vertex. Touch support for mobile devices is implemented.
There are still some limitations like direction arrow points only to north or some data values available only on high-end devices like power are not yet implemented etc, but as I already mentioned above, this app is subject to improve especially for the newer devices, where there's a lot of memory available even for the data field type of app. The web app is also meant to be improved especially in a direction to provide the nearest possible WYSIWYG snapshot of what you'll actually see on device, but there are also some limitations like, for example, font, which is used as numeric font in the latest Fenix5/FR935 models is not and won't be publicly available (confirmed by Garmin officials explicitly) and I used nearest lookalike, therefore there still may be some couple of pixel differences here and there between device and web app. For these kinds of problems I can only test and fix using the user-provided layouts in specific device simulator as I'm a simple FR230 owner for real testing and I'm afraid this won't change in the nearest year unless generous users will help me to upgrade.
Web app may eventually become mobile application based on the user feedback (but not for the Apple devices, Android only).
    - having min elevation and max elevation. I think this should be simple (and not using too much memory). Because total ascent is often not reliable (on FR235) so when I run up and down the min and max are more meaningful to me.
    This is not hard indeed, but we are nearing internal field ID limit, I still have some free numbers but I'm still not sure if I'll be able to make most of the new request available of it'll be necessary to increase ID range which will involve definition reencoding and will require of the web app to provide backwards compatibility... Not that hard either but will require considerable time to implement it right.
    - possibility to set sample number for graphs. As far as I understand, the data on a graph show a duration based on the number of pixels (1px = 1s). So changing the sample number would allow a graph to show data over a longer duration, for example to see the elevation profile over the last few hours.
    - following (or instead of) this, I was thinking of an option to have the full graph over the activity by resizing the graph. The simplest way to do this might be to dynamically multiply by 2 the number of samples when the elapsed time is too big for the graph size.
    Currently graph bar width defines number of graph samples and that width can not be changed freely since I only allow to set values which will provide decimal result for (graph width / graph bar width) to keep display element width constant. Idea of activity size scalable graph was one of my initial intents, but I postponed that until the time when I'll understand implementation strategies as there's simply not enough memory to store samples for the whole several hours long activity to select only ones to be drawn at any specific moment of time, therefore at some point I'll need to pack already present graph data and for that I'll need to understand exact moment based on current scale and graph/bar width. As you can see it's still a little bit vague at least on my side, but I keep all of my ideas listed and look at them from time to time to check whether something new has unearthed 8))
  • Hi,
    Thanks for the quick reply.
    I understand that you have many requests and technical limitations so do what you think is the best, I'm already an addict of this app !
    Just a precision concerning my suggestion of multiplying by 2 the samples number. As I see it, it would be a way to avoid saving data for the whole activity since you can simply reuse the data already used for the graph (just take one over two). And the moment for packing the data is simply twice the elapsed time at the previous packing (and the first packing at 'graph width' seconds).
  • ... I'm already an addict of this app !
    The same with me!
    I'm that happy with my DIY created datafield, that I decided, I will only buy the new Edge1030 if Easurovov enables DIY for the new device.
    If not I will stick to my Edge 1000.
    1) Average power of first lap (the one at activity start) is not correct, the value increments too slowly. The longer the lap the better it matches the correct value.
    2) During any lap: if I stop (speed=0, timer stops, but activity is still active), the average power value drops (slowly). That shouldn't happen, the value should stay at its current value. That's also the behaviour of Garmin's average lap power. If I continue the ride, average power calculation should also continue.
    Hi easuvorov,
    sorry to quote myself...but did you had some time to check the average power calculation...?
    Thanks.
    Yes I did, but the solution is still not clear to me:
    problem is that currently I start to calculate number of samples at the moment you enter activity (samples are zero at this time and we decided to include zero samples), I continue to increase counter during the time before you even press "Start" therefore it may give huge false start threshold which may/will synchronize with native value much later indeed.
    For me the most obvious solution was to use timer time in seconds as the number of samples, but extensive testing shows that even in Edge 1000 device simulator despite it being one of the most powerful Garmin devices my "compute" section is called not at exact second ticks and sometimes I can even see skipped seconds if I place timer time on the same layout. I tried to compare timer time with my internal number of ticks and these numbers start to differ by considerable value in the long run, therefore usage of timer time as the number of samples is not reliable.
    Next solution is to start/continue increasing number of samples only if timer is running, but timer state is available for fewer devices that are currently supporting lap values, therefore this solution is not universal.
    I'm experimenting with more universal approach which keeps timer state based on timer events (which are supported on all modern devices), but since I do not use global variables to reduce memory footprint this requires of me to take cautious approach with rewiring of the whole internal application data storage. This is not that complex but requires a lot of attention and time for a research since your activity has very long first lap 8))
    That should be the solution...: start/continue increasing number of samples only if timer is running.
    To support your testing and development, please let me know if you want me to provide a fit file with a specific number and/or duration of laps.
    Hi, easuvorov, thanks for the 0.72 version, with this new A B C function it's now easy to create and visualize similar night and day options for the same layout, just by changing screens.
    There is another point that I don`t actually know if it's app related or a major garmin bug, so if you guys are experiencing the same and could get a light on that, I would really appreciate. Both my device and my garmin connect settings are set to the metric system. But every time I do a sync, the distance (yet not the speed in my DIY screen) changes from km to miles, if I just access the settings and change from statute to metric, the change will only apply for a default garmin data field and not my connect IQ data field, but when reload the DIY data screen on my settings, then, yes! it comes back again to the metric system. Now, what is bothering me is that for the moment I need to do that before every ride.
    Any thoughts on that?
    Thanks!
    Hi easuvorov,
    I tested v0.72 today. I'm not 100% sure that issue 1) is solved completely, average power of first lap still looked lower than what Garmin's data field reports. I need to check that again.
    But item 2) is correct now, average lap value is within +/-1 W of Garmin's average power and calculation stops if the timer stops. Good job!
    Thanks!
    I noticed the same on my Edge 520. I'm sure it's related to latest firmware update (v12.20). On every power-on distance settings is set to miles. Even if I change it back to km it's back on miles after next power-on. Very annoying.
    DIY seems to check this setting only once - probably at power-on I guess - because if I change the setting from miles to km during an activity, DIY does not change the distance field to km, it sticks with miles. Garmin's distance field does change to km, though.
    I tested in Edge device simulator side by side with native average activity power (which presumably should be equal to the average power of the first lap) and also noticed the difference. Problem is that I do not understand how this native average value is calculated, because it's definitely not equal to (total / number). The only workaround I can think of is to use native average activity power as lap average power for the first lap and then calculate using total amount and number of samples starting from the second lap if you insist that Garmin value should be matched, but frankly this looks like hardcoding to me...
