Chrono Style Watchface
Hello,
this is my first contribution to this forum and my first watchface.
It's called chrono style watchface and you can find it in the store.
https://apps.garmin.com/de-DE/apps/66ee453a-cd28-4620-ac1d-e6e7e15689cc
If you want to support me: https://www.paypal.me/Dirk72
Features:
- Chrono style look
- Activity gauge: Steps, distance, daily goal, history steps, calories
- Altitude gauge: Hand displays 100m or feet, triangle displays 1000m or feet
- Battery gauge: Hand displays 10%, triangle displays 100%
- Sunset/Sunrise gauge: Displays the next 2 sun events, solar altitude, time until next sun Event
- Sensor history gauge: history field, hand displays recent value, triangles display min and max values in history, scale auto adjusts (Fenix 5 derivates only, HR works with F3HR and supported Forerunner devices)
- Moon phase gauge: moonage, days before and after fullmoon, arc also shows moon phase
- Small moon phase gauge
- Digital watch with 2. time
- 2 configurable digital fields with date, clock and heart rate (on supported devices)
- Activity level showing on margin or micro bar
- Notifications
- 2 hand styles
- Micro battery Icon
- Cycle through activity info while active
- Bluetooth Icon
- Blackout Edition
- a lot of possibilities to configure colours and functions of the watchface
I have several reasons why I post here:
1. A lot of people had good suggestions and helped me to get the watchface to its current state. Thank you for that. It's a lot easier to discuss suggestions here than via email or the connect iq store.
2. Since I "only" own a Fenix 3, I can't test every feature of my watchface myself and so I need a platform for people, who want to help and give feedback. Um well yes, I want you as beta testers :rolleyes:
So here we are. I am awaiting your wishes, your feedback and your comments.
Cheers
  • Version 1.15
    Fenix 5X
    Sun Rise WORK !!!
    new gauges with graphs works
    new microbattery with setting briliant idea work
    love it !!!!!!!!!!!
    very little issue i use barometer in millibars but on gauge writen hPa
    but it tiny thing
    Thank You for hard work !!!!
    Hi,
    <smartass mode on>
    The hectopascal is the international unit for measuring atmospheric or barometric pressure.
    1 hectopascal = 1 millibar.
    <\smartass mode off>
    Well the truth is, hPa is shorter than mbar and 4 letters wouldn't fit into the small gap at the bottom of the gauge... :cool:
    Cheers
    Hi,
    sounds good, thank you for the info.
    Cheers
    The watch face crashed again during the night around the same time that it crashed yesterday also. Not sure why this happens. Maybe its just on my device.
  • Bury ponte vivo
    Hi,
    <smartass mode on>
    Cheers
    You wright!!!!
  • The watch face crashed again during the night around the same time that it crashed yesterday also. Not sure why this happens. Maybe its just on my device.
    Ok, now that's bad news. Well, could you please tell me, what gauges you used when the watchface crashed. In addition, could you once more post your CIQ_LOG.TXT file?
    Hop
    Hello!
    Im using the elevation gauge on My Fenix 5.
    I think it crashes at around the same time everyday (~12:50 AM) and doesn't look like it matters for how long you are using it. Yesterday i had the watchface working for around 12 hours until it crashed at around 12:50am and today i used it only for about 2 hours before it crashed again at the same time. The weird thing is that no one else is reporting this error, so maybe its just me?
  • Hello!
    I will look into it. Maybe you could provide me with some more information. What other gauges are you using? Could you try to use another gauge at that time ( like altimeter instead of elevation) and see if it happens again? I guess, you are on the latest firmware?
    Don't worry about being the only one reporting that error. There maybe value constellations that cause this error, which aren't very common.
    Im using the activity and the sunrise/sunset gauges. I have the cycle through info disabled. Latest firmwae
    I just tested with the altimeter instead of elevation and it doesn't crash. I will test with the HR gauge and i will let you know.
  • Im using the activity and the sunrise/sunset gauges. I have the cycle through info disabled. Latest firmwae
    I think I found it. There was a problem, when all the values in history were the same. Bugfix is online.
    See, it's not only you, thank you for the info.
    Cheers
    Cheers
    Awesome! I installed the update. I will let you know.
    some tips for Fenix 5?
    Very good and configurable, but Fenix 5 Elevation and Air pressure gauges display always smaller values than the corresponding widgets (e.g. 1021hPa instead of 1022 in the ABC Garmin widget, as well as 27m instead of 28m). Moreover this morning after 2 floor descent from 50m to 44m it displayed from 49 (expecrted as per the issue above) to -23 (?) moving the elevation gauge scale accordingly from -400 to 400. Also min and max values in the outer ring are barely noticeable. Also the ring dots are barely visible and they should be slightly bigger.
