hi... I don't know, what's wrong, but I cannot find settings for your app in Connect Mobile (iOS)... there is just possibilty to install/uninstall...
Could you put the image of the app once you enter the data? As much as I try, I can't configure it, the alarms overlap, sometimes they don't sound. Thank you
First off – is this app still supported? If so, I have a couple of suggestions that would make it hugely more useful [on my Edge 820]: alarm duration control only affects alarm 1. I suggest making it change all the alarms [when bombing down a chunky downhill, 2 seconds is nowhere near long enough to be able to see the message]; and is there a way to make it a "pop-up" message [like sms notifications] to appear on any/all screens instead of only working when the device is showing the screen with the E!D!R! field?
I have many apps to maintain and this one is not at the top of my list, so don't expect any chances soon.
It can't be a popup no, although I worked around it a bit with the integration in the "All In One" field.
Hi Peter, I appreciate this is an old app, i've been using it since it first came out & still find it useful to remind the boys to fuel whilst racing. I'm now running it on a Edge 830 and the Custom alert length will only allow you to set 0, if you try to change it to anything else there is a warning message that the entry must be from 0 to 0.
Any ideas, thanks.
