Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • Issue on F5X
    ActiFace 5 with support for Fenix 5/5S/5X is on the store.
    Good news, perfect for my new F5X :-)
    Unfortunately, I have an issue to display the altitude ("--m" in this screenshot) :
    But it's quite strange : in the "watch selection mode", this info is Ok :
  • Good news, perfect for my new F5X :-)
    Hi, I'm afraid it's the firmware issue, but I believe it'll be fixed soon.
  • Make sure that you are on the latest FW version for the f5x.
    I had a user complain he couldn't see the HR on one of my watch faces on his f5x, but a FW upgrade solved that for him.
    Lets hope this is the same issue here?
  • Battery indicator type (Fenix 3)
    First of all: The best watchface for the Fenix 3!
    If I remember correctly there has been the posibilty to switch off the Battery indicator (green bar) for normal display.
    This isn't the case any longer with the new update.
    From the design point of view I'd like to have this opportunity back - it just looks much more elegant without the green bar (Percentage is just enough)
    lg
    Custom fields missing
    I'm running into the same issue as IACCHOS and have 2.40 firmware installed. FWIW, it also seems to be affecting other watch faces. Hope its fixed soon... This is my first Garmin watch and to unpack, start testing, and stumble into this issue is a bummer. The default watch faces do not seem to be affected.
    Nonetheless, thanks for the great looking layout, Petr!
    Nate
    No seconds anymore after update?
    Hi
    i am using ActiFace on a Fenix 3 HR.
    after i updated to the current version; i am not able to get the seconds on the display by swiping the clock.
    is there another way to get the seconds back on display by moving the arm or an other "trick"?
    Issues
    Petr,
    I've been using ActiFace for over a year now on F3 and loved it. Recently, upgraded to F5X and reinstalled ActiFace. Elevation, Sunrise/Sunset fields do not update, no seconds on wrist turn (bummer), no notification counter:(. Please fix, man.
    Max
    Petr,
    Max
    I just received my Fenix 5 and installed ActiFace. My sunrise/sunset field just comes up as dashes with no data.
    I'm up to date on software 2.9.
    Hi Petr. Is it possible to add an option to disable showing the goal % target on wrist turn? Personally only interested in seeing total steps there.
    Thank you again for such a fantastic watchface.
    Hi Petr,
    My daily goal step is 10,000. Yesterday I had 10,334 and yet I do not have a white triangle on the graph for that day. Do you happen to know why? I've synced with Garmin Connect multiple times to no avail. Thanks.
