Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
    Former Member over 8 years ago
    Problems with ActiFace app
    Every time I have tried to download this app on my Fenix 3 HR it always tells me I have to download update. I have done this numerous times and it has not worked. Also with Gym pro app I have it on my watch bt can't seem to see it on my computer or phone app. Please help !
    Hi Jonathan,
    thank you, I'll look into it and will see how to implement it into the next version. It's pretty hard to find another usable space on these small screens :) There are steps and inactivity bar inside the circle and the circle itself is very close to other components. Different color can be the solution, I'll try it.
    I agree. The bullseye type effect would probably be an option to have it instead of the text inside the circle. Using different colors for subsequent iterations would use the same real-estate.
    The lack of real estate is a challenge, but I love the UI design. I've used it on the F3, 235, Vivoactive, VivoactiveHR, & 920XT so far and love it.
    ActiFace
    If someone could please walk me through installing apps on my watch would greatly appreciate it. In my top left corner of my app on my phone it has a mailbox not the 3 ones to go to my profile. Don't know why thats like that either.
    Hi
    thx for this great WatchFace.
    I noticed a problem, perhaps you can help me:
    Every time i reboot my fenix 3 HR all my settings are gone and the default settings are loaded.
    any idea what is going wrong?
  • There are two date formats in watchface configuration for Fenix3. One is the full length format and the second one is shorter for the case when you have have some notifications.
    Oops, my fault, didn't notice the option.
  • Hi
    Hmm, strange. You can try to uninstall the ActiFace, restart watches and install again. There are maybe some issues with app config files.
    I have no time for sunrise/sunset times
    Can you help me?
    On my Vivoactive hr
  • Did you try to fix GPS once to get the location?
    What you mean with fix gps? I'm from Germany.
  • Go under open sky and start some activity in which the watch will be searching for satellites. When GPS is found you will be informed - that's gps fix. Then, watches will have saved gps location and ActiFace will use it for sunset calculation.
