Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • Hi, some options are limited for some field because of their possible length.
  • Awesome watch face, thanks so much! I have a tiny request. Would it be possible to change the battery indicator when charging? I often plug in my watch only to find that it didn't charge. Thanks!
    Former Member over 9 years ago
    Daily Totals not showing up on watch face
    Hello,
    I'm very new to the Garmin 230, but I downloaded the ActiFace and set my fields, and have used the watch several times have sync'd, updated, restarted etc... and none of the information of my run, Cal burned, miles run etc... show up on my watch face nor does the graph show any data what so ever. Anyone know what I need to do to get these fields to populate?
    thanks so much
  • Hello,
    thanks so much
    It seems you have turned the Activity tracking off in the Settings..
    downgrade version
    Hi Petr,
    I´m a big fan of your watchface, i really think is the best ever made, but im a little bit annoyed with the latest updated. The sunrise icon dissapeared, i know that is because of screen space but..
    There is any way to downgrade to the previous version recovering in this way the sunrise icon???
    thanks in advance and keep pushing.
    Regards
    thanks Petr!
    Ah ha!
    you were correct, the situation has been remedied... thank you for the help and keep up the great work.
    Fenix 3
    On the face at the left side there is a red line right on the side. Its there from time to time and I don't know what its for?
  • On the face at the left side there is a red line right on the side. Its there from time to time and I don't know what its for?
    Hi,
    It's the inactivity bar, the same as on the default watch face.
    Seconds display
    When I display seconds, they only appear when I shake the watch (vivoactive HR). Is there a way to get them to be displayed always?
    QUOTE=Petr.Koula;522453]ActiFace 4.1
    You can also try a new lightweight ActiFace Steps https://apps.garmin.com/en-US/apps/677da56c-7cc2-4547-ad49-0aef9022ef90
    !!! IMPORTANT - PLEASE, UPDATE YOUR GARMIN EXPRESS IF YOU HAVE SOME CONFIGURATION PROBLEMS !!!
    - Time and date
    - today's distance
    - today's calories
    - optionally sunrise/sunset time
    Configuration
    Possible settings:
    - Color
    - Custom field
    - sunrise/sunset times
    - altitude (Fenix3 only)
    - Color graph line
    version 4.0 changelog:
    - added support for Vivoactive HR
    - added darker colors options
    - added new custom field Altitude on Fenix3
    - added battery indicator type configuration on Fenix3
    - added possibility to make graph line colored according to progress
    - added possibility to disable battery percentage on FR230/235/630
    - changed goal progress bar and inactivity bar on FR230/235/630 (they were swapped)
    - changed battery color behavior - green to 50% (was 55%)
    - improved fonts on FR230/235/630
    - fixed graph lines overlapping the grid
    - other minor fixes and tweaks
    - recompiled with ConnectIQ 1.2.6
    version 4.1 changelog:
    - added possibility to invert colors (white background)
  • No, that's standard custom watchface behavior which saves your battery.
