Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • Hi Petr. Been using this face along time and it's been working excellent.
    I have a small request - would you be able to add options to see active calories for the day? Perhaps have option to see this in either the total calories currently is and also above where the day's distance sits?
    Unfortunately I don't have this data available.
  • I've updated my Forerunner 920XT to SW Beta 8.03.
    Looks like with it the sunrise/sunset icons have vanished.
    Just for info...
    I think that ActiFace has automatically updated as well and the latest version is without these icons to make more space for custom fields.
  • I think that ActiFace has automatically updated as well and the latest version is without these icons to make more space for custom fields.
    Hi Petr!
    You're the developper so you should know instead of just think *lol*
    Well, there's still some space right of time on 920 XT but not enough to show some other custom field I guess.
    I was wondering wether these symbols are still exist in new fw/SDK ;-)
    Best regards,
    Olly
  • Hi Petr!
    Best regards,
    Olly
    I can't know when your device is scheduled to be automatically updated :)
    The altitude and sunrise/sunset icons have been removed from the application, not from fw or SDK. That's because I added new system of configurable fields and had to remove these icons to make it universal - cross-device compatible solution.
    seconds on ActiFace
    i have install acti on my 230 and the only "bug:confused:" i found is that alot of times the icon of seconds on screen disappears ,hope to fix that, good work thanks for the face ;)
  • Hi there and congrats on the awesome watch face!
    My understanding is that if I choose to display distance on the 7 day plot, then it will include both the distance during a Running activity as well as the walking distance based on the step count. Is there a way to configure it so that it shows *only* the distance I have actually run in my running activities?
    I am a runner and I don't really care to see how much I walked each week (although it's quite a lot)
    Thanks!
    Thanks!
    Hi, unfortunately, I don't have data about activities available in the watchface, only from the activity tracker, where distances and calories are mixed from all activities during the day.
    Latest Connect app update (android) confuses 24-hour watch
    Since last app update ActiFace 24-hour watch shows 01:03 at 05:03 and 1:05 at 05:15. Switch between 12-hour and 24-hour seem do nothing. Will investigate if newer firmware for watch (currently FR235 on 4.70 a172515) are available. Please advise. Best Regards. Per-Fredrik
  • Since last app update ActiFace 24-hour watch shows 01:03 at 05:03 and 1:05 at 05:15. Switch between 12-hour and 24-hour seem do nothing. Will investigate if newer firmware for watch (currently FR235 on 4.70 a172515) are available. Please advise. Best Regards. Per-Fredrik
    Hi, do you have set time automatically in the watch settings? If so, try to restart and fix GPS to update time.
    Fixed- Latest Connect app update (android) confuses 24-hour watch
    Great, that did the trick!
    Cheers!
