Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
    Former Member over 9 years ago
    Can you insert blank symbol before day of week?
    In my Garmin-920 day of week stuck with left side of border and it's uncomfortably to read day of week.
  • I second this request. Being able to use the barometric altimeter without GPS is important for saving battery life when in the mountains.
    Ok, thanks for ideas.
    I love your watchface...
    A little request... can you add support for altitude with Vivoactive HR? In other watchface it's supported, but I prefer yours! :D
    THANK YOU!
    I support this request as well, your WatchFace is awesome. Also if you could add HR for the VivoActive HR it will be great.
    Love this watch face.
    I apologize - I'm sure this has been answered - but at over 80 pages I just haven't searched through for my answer though I saw other people mention in before.
    I used this watch face for weeks - without a bluetooth connection to my phone - and everything worked on it.
    Since now connecting to my phone and garmin connect app - the sunrise and sunset no longer shows. It always did before.
    Is there a easy fix for this?
    Thanks!
    (PS - someone had mentioned having the option to change the colour of the minutes - and that would be great!) Used that option on my last watch face for many months.
    Wrong Sunrise and Sunset
    I have just installed your ActiFace, and I find it great!
    Only it shows incorrect sunrise and sunset... now (June 1st, 11:22 AM), it tells me that sunset is at 12:40:confused:! Strange, isn't it? Real sunset will be at 20:53!
    Can you fix it?
    Thank you
  • Fantastic watch face! Thanks for your hard work on this.
    Quick question about the graph though - what do the various colors represent? I'm not seeing that documented anywhere.
    On the current day column in the graph, it slopes downward and uses the following colors (in order): Dark green, white, orange, red. The pixel height of this curve seems to be a bit thicker than the top line of the graph too, if that makes sense.
    I have the top of the graph set to white and the shaded portion to green, FWIW.
    Manual?
    I'm looking for a more detailed description of that which I see on a Garmin Vivoactive HR for the ActiFace watch face. Specifically, the meaning of the graph and various line colors within the graph are unclear.
    Thanks.
    Thanks.
  • I love the watchface but I was wondering, is there a way to display only the running distance instead of the "total" distance; meaning including the one coming from steps?
    I personally use my 735xt as a running tool only (running 60mpw) and I just want to track my mileage and not "steps" or other "activity monitor" stats.
    Is that currently possible in Actiface or is there a different watchface that can do that?
    Hi, the API is not currently exposing this data.
