Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
    Hi, and how big is the error? Where are you from?
    Hi, I'm from Hong Kong (GMT+8).
    The time is now 08:34 and the sunrise time is displayed as 09:42. It looks like to me it is the timezone issue, but my profile (location) is correctly set and I have already reset my watch after installing the watchface so I don't know what went wrong. :(
  • Hi, I'm from Hong Kong (GMT+8).
    I tried it in the simulator and didn't see any problem. Do you have set time automatically from GPS?
    Cannot install to Fenix 3 HR
    Hi,
    I am trying to install to Fenix 3 HR but I keep getting "This app requires an update of your fenix 3 HR. Please use Garmin Express to update your fenix 3 HR." I have searched your thread and restarted my Garmin Express to see if there are any more updates but there aren't and I still get the same error.
    Firmware version is 3.0. Please advise.
  • Hi,
    Hi, it's a bug on Garmin side, currently being fixed, please be patient.
    Actiface
    I love the Actiface app on my Garmin Forerunner 235...best app yet!
    Unfortunately, when i went into Run mode yesterday, my watch went through an update process...didn't pay attention to exactly what it did, but it took about two minutes. I went for my run then, and when i went out of run mode, the standard face was in the place of Actiface.
    I went through several steps both alone and with Garmin support:
    -Updated the watch to 4.30 (3de7d5e)
    -Uninstalled the app from Garmin Express
    -Re-downloaded the app and installed again
    -Verified that it appears in the App Manager (it appears in the list as "On Your Device" and as "Watch Faces"). There is an 'x' in the circle next to the app name, not the little cloud icon.
    Nothing works and i can't get it back on my watch. Hope it can be fixed. Thank you!
  • bbr0wnrigg-
    Did you try:
    When you're seeing any watchface, long press the "up" button, Select "Clock Options" and then "Watchface, and you can choose which of the watchfaces on your watch you want to use.
    Many thanks!
    Thanks for your rely.
    Yes, I have set time automatically but still.
    Thanks for your help, your watchface is great and I'll just turn sunrise/sunset off for now. :o
    Hi Petr
    I love your watchface, thank you for that. But unfortunately, since the last update (Fenix 3 7.00, Actiface 4.1.1 upd) the activity history graph shows only yesterday and today (since three days).
    I tried further update, deinstall an reinstall Acitface several times but doesn't help.
    Do you have an idea what could be the problem?
    Thx for help!
  • Hi Petr
    Thx for help!
    Hi,
    I'm affraid that the problem is not in the watchface but in the update which deleted your activity tracker history.
