Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • Thanks for the Update.
    Looks great with the inactivity indicators.
    Graphs are ok, but summaries distance/calories are wrong.
    Not sure, already in the last version (didn't observed)
    I need not the summaries, but I hope the picture helps you.
    920XT, V3.20
  • Hi all. If I look at the picture it seems to be OK and it's on par with the table. Graph shows total distance and total calories for last 6 days + today. Values above the graph are not week totals but week maximums. It gives you a graph scale. Only changing is always the right column and after midnight it shifts to the left and creates a new today column. Note that daily totals counts together activities and other walking from that day.
  • Hi, I have the same problem with 920XT. the only part of the graph that change is the calories and kilometers of the day (today). The rest of the graph is always the same, it doesn't cahnge.
    Hello Sim-Cat,
    I experienced the same behavior with my 920xt.
    It seems that the daily steps are only stored to the step history if the watch isn't turned off at midnight.
    I suppose that there are no older entries in your watch step history an this is the information that KOULIK displays on his graph.
    Just leave the watch turned on for several days (or turn it off not before midnight) and you will have a nice graph.
  • Values above the graph are not week totals but week maximums.
    ok, my fault. I didn't read it in #1
    Thanks for Info
    Thanks to all. I'll let you know next week, because I installed Actiface last monday. I only noticed the first 5 columns don't change during these days, and the values of the km and kC are always 25km and 2568....
  • Thanks to all. I'll let you know next week, because I installed Actiface last monday. I only noticed the first 5 columns don't change during these days, and the values of the km and kC are always 25km and 2568....
    And is it adding one graph column each new day? Because it should show 7 days including today. It's correct ff you bought or reset your FR920XT 5 days ago and there will be 7 columns on Sunday. Then, graph will be shifting left each next day. In case you are using your watch more than 5 days without any reset, there can be problem with the history statistics. You can check it in menu > History > Steps.. There already were several cases when activity tracker was not saving history data and must be reset.
    Values above graph are changing only when you reach a new week maximum per day or if the day with this maximum is older than past 6 days..
    Let me know, please. Thanks..
    Can you add AM and or PM to the watch screen?
    PS. Fenix 3 Software version 3.10
  • Great watch face thank you!
    Two question, how many minutes of inactivity does each red dot represent? I know when all 5 are red means 2hrs+, does it just get divided straight like 24min each?
    Also how many steps needed to clear the move bar? thanks
    Thank you for your feedback. Can you check your activity history on F3? It should be somewhere in the menu. Is there listed correct values for today and previous days? Would be nice if you can post a photo of the watchface, it can help.
    Thank you. I actually noticed that I had some prior issues. My distances were not being recorded, but my steps were. I suspect it was a result of some funky watchface I was having issues with on older firmwares. I just reset the watch and reinstalled a few things. The graph looks "correct" at least as far as I can tell. As of now, there is only one table, I suspect it will generate a new one at midnight? I will let it run for a few days and report back.
