Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • I have à Fenix 3. Automatic goal is set to off and it says 10000 in the Connect app.
    And are you on fw 6.15beta? If so, it can be affected by a bug RealHunnymonster wrote about. And what goal value you see if you scroll downt to activity widget (the one with arc graph)?
  • If the user is on 6.15beta on Fenix 3 - it has an automatic goal issue (whatever you set, the device persists in automatically setting the goal)
    Ok thanks I have 6.15:rolleyes:
  • Ok thanks I have 6.15:rolleyes:
    OK :) thanks for info
  • Seconds
    Hallo again ! Thank you for a wonderful watchface. It's my favoriteapp. I read about seconds. It would be nice to have seconds even if they only lasts for 6 seconds
    Former Member over 9 years ago
    Slows down watch?
    Awesome watch face! I only have 2 issues:
    No seconds. I can live without but it is annoying.
    The other issues is that it slows down my F3 completely. It's enough that I keep changing back to the standard digital face and change back to ArtiFace to see my average calories and kms.
    Does anyone else have this issue or know how to fix it?
  • The other issues is that it slows down my F3 completely. It's enough that I keep changing back to the standard digital face and change back to ArtiFace to see my average calories and kms.
    I've found that using the average distance and kc will slow it down more than using the maximum or total. I'm guessing there is another level of calculation required?
  • Interresting, I'll look at it. Average option does only one more math operation against totals and maximums. All of these metrics are calculated only once each 5 minutes or when you go to the watchface from other screen. I'll do some optimalizations if I found places to do it. Thanks for your feedback.
  • Sleep Mode Icon
    Maybe I missed the discussion, but it is possible to add the Sleep Mode Icon at it was shown before 2.0
    Holger
    Great watchface could be even better
    ActiFace
    Version: 2.0
    ActiFace Red is no longer supported. Please install ActiFace 2.0 for the latest features.
    Please, leave your comments, bug reports and ideas on this forum:
    https://forums.garmin.com/showthread.php?213535-Watchface-ActiFace-FR920XT-Vivoactive-epix
    Some features (i.e. notification count or configuration) require the latest device firmware with Connect IQ 1.2.
    - Time and date
    - today's distance
    - today's calories
    - red/gray dots (Fenix3 or FR230/630) or "Z" characters as inactivity indicator (shown only when there is some level of inactivity; five red dots (or Z) is maximum inactivity)
    * First dot (or Z) is shown after hour of inactivity and then one dot (Z) each 15 minutes up to 2 hours. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
    - badges - "D" - doubled goal, "arrow up" - week maximum reached, "4" - you reached the goal 4 times in past 5 days (including today), "7" - you reached the goal 7 times
    Configuration
    Possible settings:
    - Color
    Badges
     - you've reached the week maximum distance
     - you've doubled your step goal
     - you've reached the goal 4 times in a row in past 5 days (including today)
     - you've reached the goal 7 times in a row in past 8 days (including today)
    I love this watchface!
    Would be great if you could add another option for the white line to show total activity duration per day.
    //Sjur
