Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • Yes, I have 3.3 on my VA and my CIQ is 3.1 I've tried restarting both several times and still the the error and no changes to my watch face.
    Uhmm, I don't have any idea at the moment. I'll try some tests on my VA later today. Can you try to uninstall and re-install ActiFace again (in case you already haven't tried it)?
  • Was my favourite watch face - thanks for all your hard work.
    However after latest Fenix 3 update to Firmware 5.0 including IQ SDK 1.2.1 I just get a blank screen which then reverts to the standard 'boot up' digital delay.
    Any help you can provide would be much appreciated
  • Same.
    Blanck screen with Fenix 3 fw 5.0
  • F3 fw 5.0 issue
    Hi, SUPER watch face, i've update the Fenix 3 with fw 5.0, Garmin Express and the new ver of Actiface, BUT selecting "orange" color will crash the F3 and the watchface become the stack one; do you know about the issue with this color?
  • Hi, please can all of you had crashes with the latest firmware provide me info if you are using GCM for Android, iOS or just Garmin Express or if it crashed without any configurations?
    Are you on ActiFace 2.0.4?
    If so, can you post CIQ error log file from /GARMIN/APPS folder?
    Thanks
    Hi, what firmware do you have on your Epix? I've 2.93beta installed and ActiFace works fine. Have you installed the latest version 2.0.2 of the ActiFace?
    I'm on 2.90 (latest release). I'm now having issues with my 920XT and AF.
  • I'm on 2.90 (latest release). I'm now having issues with my 920XT and AF.
    Latest for epix is 3.10 and 6.10 for 920xt.
    Ok, so I tried to uninstall and got the same "Device Communication Error" immediately after I hit "uninstall" and for some reason it reminded me of the computer error that says it can't do a requested operation because the file is in use... hmmmmm...
    So I went and changed my VA to a different watch face and went back in CIQ and hit update again on ActiFace... Bingo, No Error! Went and changed my VA watch face back to ActiFace and sure enough, the updates had taken hold.
    Apparently it doesn't allow updates while it is the active watch face.
    Thanks!
    Thanks
    Fenix3 with official fw 5.0, GarminExpress PC ver 4.1.10.0 and latest ActiFace update (attached the log)
  • Many thanks! :) Please, update your ActiFace to the latest version 2.0.5.
    There is a bug in Garmin Express 4.1.10.0 causing that properties are propagated to the watchface incorrectly and the watchface crashes. I fixed these crashes, but settings via Garmin Express are still broken and some configurations don't work. This bug will be fixed soon in the Garmin Express version 4.1.11.0, so please, be a patient.
