Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • Here is a picture of it on my Epix.
    Thanks..
    Hmm, it could be better with bigger font. I try to find another.. But custom font will be always uglier than native because it is not smoothed by antialiasing. And 24h format (i.e. 22:23) is pretty wide, so it's not easy to find the correct font. It's a shame that native font of this size on Epix is much bigger than the same size on other models.
    I've just uploaded new version 1.8.1 with standard Roboto font for Epix, can you try it?
  • Install both blue and red ......
    I have tried and I am guessing there is no way to have BOTH red and blue versions installed at the same time?
    I have a Fenix 3 and was hoping to have BOTH versions installed at the same time (not selected and in use at the same time but only installed).
    When I go to do this, one version is always automatically UNINSTALLED.
    Why do I want both?
    I have a blue band and red band and it's kind a cool to match up the watch face colors.
    I'm guessing this is a Garmin limitation?
    Thanks
    Former Member over 10 years ago
    I personally like the Roboto font much better.
  • I have tried and I am guessing there is no way to have BOTH red and blue versions installed at the same time?
    Why do I want both?
    Thanks
    Garmin will allow watchface configurations via Garmin Connect Mobile in late September, then I'll make the color configurable. For now, both Actiface Blue and Red have the same name, because it can't be changed.
  • An issue on epix
    Hi,
    Fist of all congrats for this great face. I detect an issue that maybe is not due to the face, but that happens when a reboot is done on epix. The Activity done (steeps and sleep information) is gone in each reboot, and in the history appears a new "today" on Activity for every reboot (empty with no steeps). ActiFace then adds a this "fake today" on the chart, showing, for every reboot a new empty column.
    As an example on a day with 7 reboots the chart will show a chart with no information (all empty) since the new 7 "fake todays" the epix creates.
    I'm not sure if this behavior happens o everyone, or only to me.
    Regards,
  • 2 RFEs
    Thank you for creating this amazing watch face. I have 2 RFEs:
    1.- Swap location of todays distance and calories with the Max values. I have trouble seeing todays calories on the Fenix 3.
    2.- Any way to add your recovery hours? Somewhere you can cram 2 digits on the face that if the recovery time is greater than 1 hour it shows up..?
    Also, totals for the week vs Max values would be great as others have noted.
    I switched from a Polar V800 to the F3 last week and the data your display on this watch face played a small part in the investment. I went from being morbidly obese the first 20 years of my adult life (going up a single flight of steps was a major deal then) and just in the last year and half have become fit. I track my food intake daily with MFP and have daily exercise goals regarding calories I need to burn in exercise, cardio fitness goals (VO2max, resting HR, recovery HR), strength training, and running goals. The graph on the watch face enables me to, at a very quick glance, see how I am doing with my calorie burning goals today and over the week which both helps motivate me and maintain accountability. Thanks!!!
  • Hi,
    Regards,
    Hi,
    I'm affraid that your activity tracker is somehow stuck. You should try to reset your Step totals and then do a master reset if step reset didn't helped. The ActiFace doesn't create any records in the history, it only reads all available history records.
  • Thank you for creating this amazing watch face. I have 2 RFEs:
    Hi Scott,
    I'm pleased that ActiFace is motivating for you and that it can little help you. Thanks for your comments.
    To your proposals..
    1 - I'm going to make today calories white, same as today distance.. I'll change "kC" units above the graph (as a legend for graph colors)
    2 - unfortunately custom watchfaces don't have the recovery time available in their API.. Anyway it could be very useful, I hope that Garmin will add this information to the API.
  • Version 1.8.2
    - today stats are completely in white for better visibility
    - added white and color arrow next to maximums as graph color legend
