Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • Hi folks
    Nice job:D
    I have two things I would like to have on the watchface. Seconds and an icon to show me my alarm is enabled.
    Thanks in advance.
    Johnni Perschke, Denmark
  • Hi folks
    Nice job:D
    Thanks in advance.
    Hi and thanks. In fact, seconds in custom watch faces don't make sense because watchface is normally refreshed once per minute. And alarm settings is not currently available for custom watchfaces.
    Former Member over 10 years ago
    And in which way are you trying to install watchfaces? Garmin Connect or Garmin Express?
    I try to install these programs with Garmin Express. I got it a few weeks ago , has to install one but not for some time ... I tried resetting the watch , uninstall and then reinstall everything ... nothing
  • Hi Koulik,
    Firstly thank's for an awesome watch display
    I have just updated to your new version on my Vivoactive using software 2.80
    And am Noticing that the days only number 5 Now instead of 7
    and the graph alters shape between the lines as well...
    presumably this is a bug..?
    Also is it possible to make the green triangles slightly larger as they really aren't noticeable
    Regards
    steve...
  • Hi Koulik,
    Regards
    steve...
    Hi Steve,
    thanks for the response. As I understand your graph now shows only last 5 days? Is it possible to make a photo for better analysis of your issue? Can you check your step history if it is available on Vivoactive? Are there also other days beyond the 5 days shown in the graph?
    Concerning to goal triangles, it was a little purpose to make them subtle. But on the other side, I understand that it must be hard to notice them on the Vivoactive as it has dimmer screen then other Garmin devices with Chroma display. I'll try to make them bigger either for Vivoactive or for all devices. I need more feedbacks about this.
    Petr
  • I try to install these programs with Garmin Express. I got it a few weeks ago , has to install one but not for some time ... I tried resetting the watch , uninstall and then reinstall everything ... nothing
    What about try to install older version of the Garmin Express? I noticed some strange issues with updating and installing of CIQ stuff with latest versions.. So maybe it can help. Otherwise you should contact Garmin support.
  • Hi Steve,
    Petr
    Okay petr, I reached my goal 5 times in the last 5 Days
    I have attached a photo hopefully this will help
  • Okay petr, I reached my goal 5 times in the last 5 Days
    Hi,
    it looks like your Vivoactive provides just these 4 days + today to the ActiFace. Can you find your steps history for all past 7 days on your Vivo? The ActiFace doesn't store any data, it only loads them from internal history. I hope that another day (column) will be added tomorrow and you'll see 5 days + today. Let me know if so, please. Anyway, it's strange that the ActiFace update cut your history.
  • Hi,
    Ah! Just installed a step app, and this is showing me just 4 goal days and 1 were I didn't meet my target
    So it looks like your right and I will see another day (column) added tomorrow
    Thanks for the help
    Much appreciated...
    Regards.. Steve
    not syncing to my device any more. tried factory resetting, no success.
