Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
  • The watch face doesn't have access to information about rides/runs/swims. It only has access to the step history, and that is the graph that you are seeing.
    Not quite sure about this one.
    The data in my excel-sheet was from the Steps screen in Garmin Connect.
    Why are the 66km shown (62km bike ride and 4km additional steps) but not the runs from Sunday and Tuesday?
  • The ConnectIQ API only provides access to the history data in described here. It isn't clear to me if the distance and calories value include swim/bike/run or not.
    What do the Health & Fitness > Steps and the All Activities > Active Calories reports pages in Garmin Connect look like for the date range in question?
    Travis
  • Hello KOULIK,
    thank you for this watchface. I think the history graph is a great idea.
    Obviously there is a problem with the history graph on my device:
    I got my watch replaced on Feb. 24th and updated to 3.03. beta immediately.
    The watch is in use for nine days now and the history graph shows the bike ride on Feb. 26 always on the same position.
    During a day with many kilometers the graph updates correctly but on the next morning the data seems to be gone.
    Any idea what is going wrong here?
    Thank you.
    Daniel
    Hi, there was a bug which has been fixed in version 1.1.1. Previously it was loading history from wrong side of the array. Please, find the watch face in Garmin Connect and send it to your device again for update. It will be ok immediatelly. Thank you.
  • My ActiFace graph shows the correct daily distance totals for the last 7 days for swim/bike/run/other, the same totals that are shown here:
    connect.garmin.com/.../activities
    to
  • Distance includes steps + activities
  • Hi, there was a bug which has been fixed in version 1.1.1. Previously it was loading history from wrong side of the array. Please, find the watch face in Garmin Connect and send it to your device again for update. It will be ok immediatelly. Thank you.
    Thank you for your answer KOULIK,
    but i'm already on version 1.1.2 as I can see the runner icon into the goal circle when inactive for some time.
    I additionally removed the WatchFace inside GarminExpress and loaded it again from the app store. But still no luck with the graph... :-(
    Also it only shows six vertical lines in the graph, think it should show seven right now as there are more than seven activities on the watch.
    Don't know what went wrong.
    @bwd1: Are you also on FW 3.03 beta?
  • Weird, I'll be looking for the cause of this. Can you check the history data in statistics on your 920 if there isn't something? Does it correspond to GC data?
  • Moreover, it shows only 6 days :-/
    It seems like if your 920 is not saving history of activity tracker from March 1st.
