Watchface: ActiFace [FR920XT, Vivoactive, epix]
Watchface link: https://apps.garmin.com/en-US/apps/7ef071c3-4a14-4eb3-aca9-e3a531262711
You can donate the ActiFace development via PayPal here: http://bit.ly/1RoLv4i
!!! IMPORTANT - PLEASE, RESTART YOUR WATCHES AFTER WATCHFACE UPDATE IF YOU HAVE SOME CONFIGURATION ISSUES !!!
Watch Face contains:
- Time and date
- activity history graph (past 7 days + today) in kCal and km/mi (or steps)
- maximum or sum or average kCals and km/mi (or steps)
- daily goal progress and step count
- custom fields
- status and notification icons
- inactivity indicator. Removing of inactivity levels is handled by the watch firmware, usually it takes about 3-4 minutes of walking.
- "goal reached" indicator in the week graph (small white triangle)
Supports 12/24 time format and km/mi.
Configuration
ActiFace can be configured via Garmin Connect Mobile or Garmin Express.
Here is how to do it: https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
Possible settings:
- Color
- Date format (and second date format in case when the notification icon is shown on Fenix-like models)
- Inverted mode (white background)
- Graph description - values above the graph - week maximums, sums or averages
- White line - switch between daily steps and distance for the white line graph
- Color graph style - switch between curve graph and bar graph
- Custom fields types (differs between models):
* UTC (with TZ offset)
* UTC24 (with TZ offset, always 24H format)
* steps
* distance
* calories
* goal percentage
* heart rate
* altitude
* week goal percentage (counted all step goals and steps from the beginning of the week)
* week distance average (counted from the beginning of the week without today)
* week steps average (counted from the beginning of the week without today)
* week calories average (counted from the beginning of the week without today)
* sunrise/sunset times
* climbed floors
* climbed meters/feet
* descended meters/feet
* week intensity minutes percentage
- Enable/disable seconds
- Enable/disable inactivity indicator
- Battery indicator type (Fenix3 only)
- Color graph line
    FX Sunrise/Sunset Fix
    For those with F5X and sunrise/sunset issues (displayed as --/--) to fix do the following:
    -Ensure ActiFace is disabled (use custom watch face)
    -Start activity that uses GPS then discard activity
    -Enable ActiFace watch face and sunrise/sunset data will show.
    P.S. Before doing all, ensure sunrise/sunset fields is enabled in ActiFace
    Enjoy
  • For those with F5X and sunrise/sunset issues (displayed as --/--) to fix do the following:
    Enjoy
    Thanks.
    There is probably one another way to get sunrise data (maybe even easier). You can keep the ActiFace active on your watches and just start some GPS-enabled activity and push and hold down button to switch to the watchface when GPS is ready. Then you can return to the activity by pushing Start button and discard it.
    Cant install
    HI
    Just got a new Fenix 5s and tried install the app. I get the message I need to update the firmware but since I am running the latest version
    I have no idea what to do. Is the app compatibe with version 4.10 on Fenix 5s?
    Thanks
    Show something other than kCal on graph
    Sorry if this has already been brought up, but is there a chance for another option besides kCal on the graph on a FR 230 or other non HR models? Would it be possible to have it show percentage of the day active/moving?
    Fenix 5X, firmware - 4.10
    Time from the time to time all Fatchface settings was cleared after Bluetooth synchronization with Garmin Connect Mobile.
    Steps were changed to distance, color from red to blue, accumulator percents was changed to no numbers. It seems default setting of watchface were recovered itself.
    How to avoid this problem? please advise! :-(
    Wishes for options
    First of all, I would like to thank you for a great watch-face and thank you for keeping it alive and well updated! Great work!
    Ok, wishes for my Fenix 5:
    - Option to show heart rate under "custom field 1"
    I lack the possibility to have heart rate, today's total distance and today's burned Kcal shown as a combination of the 3 custom fields. Is there a reason as to why all 3 custom fields can't show the same things?
    - Seconds
    Why isn't it possible to have the seconds shown? I seem to remember that at some point in time, seconds were shown on my 920xt when I turned the wrist. It would be shown for a short while, but that was ok. I lack that feature on the Fenix 5
  • Great Watch Face! Many many thanks!
    Now a wish: can you add "do not disturb" icon in the status bar?
    ActiFace 5
    ActiFace 5 with support for Fenix 5/5S/5X is on the store.
    Hi, when I try to upload this watch face for my new fenix5 I get the message: "This app requires an update of your fenix 5. Please use Garmin Express to update your fenix 5."
    I made sure I am on the latest firmware 4.10.
    Can anybody help, please?
  • It might be a silly question, but what does it mean 95% on the new Smart Training Performance progress bar ?
    Thanks
    Thanks
    SMART TRAINING PERFORMANCE
    The Smart Training Progress indicator and percentage gives you the information how your current training load compares to your overall average training performance. It uses the burned calorie counter and its history together with the basal metabolic rate (based on your fitness profile) to calculate the long-term (overall) training load and the current load. The percentage is the rate between these calculated values. The current training load is based on weighted average of calories burned during today (extrapoled by the average) and past 3 days in the ratio of 5:5:4:3 where 5's are today and yesterday. All daily calorie values are decreased by the basal metabolic rate (your calorie consumption for living) to make the training load more significant. It's good to know that ActiFace need some time to learn your common calorie loads to be perfectly realistic in the comparison of the current and the overall performance. The value around 100% means you keep your training pretty straight and regular while with the value below 90% you're probably undertrained. The values above 100% indicates that your fitness condition (or at least the training load) is improving.
