Application - HR Sleep Lite
Now in the Garmin Connect IQ Store .. HR Sleep Lite
https://apps.garmin.com/en-US/apps/d016d505-8509-4253-84e4-5180785b0762
HR Sleep Lite .. just the basics. No settings to set .. just go and sleep.
Like HR Sleep .. just simpler for those that want it easy.
Measure your SLEEP with your HR data.
Simple ... see your Current HR (or Time), Minimum HR, Maximum HR and Average HR value in the night.
As well .. see when your minimum and maximum HR values occurred.
*** Full Change Log ***
[Version 1.35] June 7 / 2017
- Fixed a bug where the app would crash with the new Vivoactvive HR firmware. It was my fault and I do apologize.
[Version 1.34] March 6 / 2017
- Removed all FIT file support.
[Version 1.33] March 1 / 2017
- Added the ability to record HR data to FIT file in Garmin Connect. The default is OFF, and you will need to enable it in Garmin Connect Mobile or Garmin Express if desired.
[Version 1.29] February 2 / 2017
- Added Vibration count (4 to 20) for use with the "Vibrate At Set HR" value. If set .. it will vibrate on alternating seconds .. until the count has expired. So it the vibration count is set to 20 .. it will vibrate 20x.
It is not something for most users.
[Version 1.26] January 31 / 2017
- Added vibration when your HR gets below a set HR value in Garmin Connect Mobile / Garmin Express. It is defaulted at 0 or no vibrate. If set .. it will vibrate when your HR hits that set HR value. It will only vibrate once .. the first time you hit that value, otherwise it would continuously vibrate, not the desired effect.
- Fixed issue where minimum HR could be set to zero.
[Version 1.23] January 17 / 2017
- improved sensor handling upon exit.
[Version 1.22] December 21 / 2016
- Allow via user setting in Garmin Connect Mobile / Garmin Express to display only minimum HR value and hide maximum HR value from screen. The maximum HR value will still be in the summary screen and data logging.
[Initial Version] December 19 / 2016
- See your Current HR (or Time), Minimum HR, Maximum HR and Average HR values. No HR settings to set and no Sleep Zones. Just simple.
- Time available via Garmin Connect Mobile or Garmin Express via user setting. Default is Time Display Off.
- See the times when your minimum and maximum HR values occurred.
- Summary screen data is orange to avoid confusion with main screen.
- Data logging available .. Date, Minimum HR value and time of Min HR occurrence, Maximum HR value and time of Max HR occurrence and Average HR values.
VivoactiveHRGuy
    Thanks for v1.36 but can you make this:
    I personally use HR Sleep and not HR Sleep Lite, but this sounds fine to me. I will do it today and release a new version.
    VivoactiveHRGuy
    [Version 1.37] August 27 / 2018
    - Changed screen to have constant Time, Current HR, Min HR, Max HR and Average as well as Min HR and Max HR times.
    - Added pause timeout setting like HR Sleep where it will kick you out of pause mode if you forget to do so. Default is 0 and you have to set a time for it to be used.
    VivoactiveHRGuy
