DataFace
DataFace
DataFace - data rich yet simple and energy efficient multi-screen watch face with unique set of features,
free of charge.
DataFace icon
Available on the Connect IQ Store
Highlights
  • DataFace doesn't drain your battery - it doesn't work in the background, and with the default settings battery consumption is very close to the predefined watch faces, and there are a few options to make it even more energy efficient.
  • DataFace is fast - it switches to/from glances almost instantly and introduces no delay while toggling the LED flashlight by double-clicking LIGHT button.
  • DataFace supports wide range of metrics in different representations - you can choose from over 135 values, including Body Battery, stress level and time to recovery, and some of them are available as graphs and progress bars.
  • DataFace has flexible layout - only the position of the hours and minutes is predefined, while areas above and below the time are grids of 4 rows and 2 columns that can contain, e.g. a large graph, or a medium graph and a progress bar, or a smaller graph and four numeric values, or two smaller graphs with one bar and two numeric values, etc. There are 68 positions on the screen where a specific value can be placed.
  • DataFace offers you up to 10 screens - you can customize data fields for each of them separately and switch back and forth based on the situation, or create a single screen with all the data you need, since you can display from 2 to 24 values at a time.
  • DataFace has rich and intuitive on-device menu - all settings are available directly from the device.
  • DataFace respects your privacy - it doesn't collect any personal information and doesn't have "Communications" permission, so everything it can access stays on your device.
  • DataFace is free - you don't have to pay anything to use all the features.
Distinctive features
  • DataFace has advanced offline weather forecasting features: barometric pressure graph is not distorted by the altitude calibrations as it can detect and eliminate unnatural pressure changes, unlike the system pressure graph in ABC and Barometer glances. Pressure trend arrow follows the one from the system ABC glance and introduces several additional states to indicate extreme weather changes beyond the usual rate. The trend can also be configured to display the numeric value of pressure change rate over the last 3 hours. On top of that, there is the Zambretti Forecaster, that gives you pretty accurate micro-local weather forecast for the next 12 hours in text form.
  • DataFace can precisely calculate Sun and Moon data: rises and sets, current azimuths and altitudes, solar noon, daylight duration, Moon phase name and illumination, etc. The data may differ slightly from the one in the default glances, but it is more likely that the DataFace's values are more accurate than the default ones. For Sun rise and set you can select system values that exactly match what is displayed in default Sunrise/Sunset glance.
Q&A
Q: Where are the settings? I don't see a corresponding button in Connect IQ and Garmin Express.
A: DataFace is configured on the device itself, and unlike other watch faces, this is the only way to customize it. If you have fēnix, epix, Forerunner or other similar 5-button watch, hold UP/MENU button, select "Watch Face", scroll to the DataFace, press START button and select "Customize". If you're using Venu or other 2- or 3-button device, hold BACK/MENU button, select "Watch Face", scroll to the DataFace and tap the pencil icon.
Q: How to use data fields above and below time?
A: These are grids of 4 rows and 2 columns, the cells of which can be merged into any rectangular area. Simply draw such a grid on paper, select any non-overlapping rectangles you want to fill with the required data and then select those areas from the menu.
Q: Why Sun and Moon related metrics show "--"?
A: DataFace needs to know your location for these calculations - just go outside, start any GPS activity, wait for the location fix, discard the activity and return back to the watch face.
Q: Can I choose another fonts?
A: This watch face uses system fonts, and there is no such feature right now, but things may change later.
Q: How can I switch between the screens?
A: You can press and hold hours to go back and minutes to go forward in the screens loop. You can also set automatic forward screens switching using single or double gesture, with optional auto-return to the first screen on the next gesture after a longer delay.
DataFace hero image
Top Replies
  • The answer to this question depends on how other watch faces are implemented, whether they run background service (this one doesn't),
    With watch faces, the background service only runs…
All Replies
  • How about a long-press button for moving to the next screen?
    Unfortunately, it's technically impossible to write a watch face that, when in timekeeping mode, would respond to touches/swipes on the screen or physical buttons. Garmin only provides the ability to process long presses on the screen.
    The colored sun and moon progress bars are very neat!
    Colored Sun bar displays additional information about dawn, dusk and noon, that would be tricky to have with only background and data colors alone. Both Moon bars display exactly the same information, and the colored version was added to have some visual symmetry when displaying both bars next to each other.
