App: Pool Swim
https://apps.garmin.com/es-ES/apps/f134a024-6ee4-47d3-8aec-3a397e3c9733
Track your pool swimming activities with your FR230 and FR235.
You can find the user guide and get support here: https://danipindado.github.io/Garmin-ConnectIQ-pool-swim-app.html
Credits
Icon made by Freepik from www.flaticon.com
You can donate my ConnectIQ development via PayPal here: https://bit.ly/2h1EMT1
Changelog
v1.0-upd.1: bugfixes. heading might drift sometimes.
v1.0-upd.2: improve heading calculation. new multicolor icon.
v2.0: support FR630. HR data.
v3.0:Initial support stroke count (feature as beta, waiting for your feedback). Several changes in memory managment and process execution for better performance and stability.
v3.0-upd.1: fix issue. data needed for stroke count analysis was not properly written in fit file. otherwise same functionality as v3.0
v3.1: discard menu: when exiting app, now you can choose between resume/save/discard.
v3.2: display summary window when paused.
v3.2-upd.1: fixed bug: duplicate lengths after triggering manual lap.v3.2-upd.1: fixed bug: duplicate lengths after triggering manual lap.
v4.0: most common pool length values and watch screen format & fields can be configured in watch. hold "up" button for three seconds. small adjustments heading. Several cosmetic changes.
v4.1:
calories can now be selected as screen field in watch menu.
new app setting "DEBUG" which enables writting of accelerometer and heading data @10Hz in FIT file (default disabled)
new feature autolap can be configured in watch menu (default disabled- when enabled, it triggers a new lap every n lengths, where n is a configuration parameter)
several bugfixes and memory enhancements.
v4.1-upd.1: bugfix calories calculation which caused crash when hr monitor is available.
v4.2: new FR630 key definition. improve how pace charts are displayed in Sport Tracks. See https://danipindado.github.io/Pool-Swim-app-v4.2-released.html
v4.3 Implement imperial units. Improve heading calibration. https://danipindado.github.io/pool-swim-app-v4-3-released.html
v4.4 Memory & stability improvements. new heading filter. stroke counting temporarily removed. https://danipindado.github.io/new-pool-swim-version-with-improved-length-detection.html
v4.5 New stroke rate algorithm. Small bugs and improvements. https://danipindado.github.io/stroke...pool-swim.html
v4.6 Garmin swim watch compatibility: recording continues during pause and stroke rate takes one arm into account only. heading chart shows now sine instead of rad. intensity field added (only 3rd party sites supporting ConnectIQ, f.i. sporttracks) https://danipindado.github.io/pool-swim-apps-improves-compatibility-with-other-swim-watches.html
v4.7 update summary window. update user guide. https://danipindado.github.io/Garmin-ConnectIQ-pool-swim-app.html
    Recording continues during a pause?
    I have used the app on three occasions and have found it works well.
    My only issue with it is that recording continues even when the activity is paused. If I press pause, I am taking a break and don't want the pause time recorded.
  • hi,
    this is a garmin connect issue. during pauses, i set the intensity level to "rest". the idea behind, is that the recording continues, and you can see how you are recovering (for instance, by checking your heart rate).
    in 3rd party sites which support FIT2 format, the rest intervals are properly shown, see:
    https://danipindado.github.io/images/intensity.png
    In the next version i will add two connectiq fields showing the total active time and total rest time so that they are shown garmin connect
    Distance stay at 0 in Garmin Connect and Strava
    Hello,
    This Apps corresponding exactly of my need.... I changed my TomTom (down) to a FR 235 and this App cover the lack of this Garmin Model.... ... except... the distance !
    I don't know why, when the activity on Garmin Connect is OK except the distance, and so... it's the same in my Strava account. Is it a bug or a Garmin restriction ?....
    Please help me because you Apps, except this point, is really what I need.
    Thks a lot for your time and involvement !
    Nicolas (French guy) ;)
  • Hello,
    Hi french guy,
    Read here:
    https://danipindado.github.io/a-note-on-pool-swim-activity-data-in-garmin-connect.html
    PD you owe one star ;)
  • Thanks
    Very good app and very hard work to develope it.
    I only can say thank you.
    Maybe the forum is for other issues, but it is also necessary to recognize the great work you have done.
  • Very good app and very hard work to develope it.
    :o thanks!
    Great App
    Hi, I have just tried the app last week and it works great. Only I would suggest if you could please add more pools sizes. My pool has only 20m or if there are too many possible sizes an option to introduce the size manually.
  • Hi, I have just tried the app last week and it works great. Only I would suggest if you could please add more pools sizes. My pool has only 20m or if there are too many possible sizes an option to introduce the size manually.
    Hi
    Check the user guide. It is described there how to customize the pool length.
    Hi
    Found it. Thanks
    Just downloaded this and am pleased with the stroke count. I was just wondering if the new version was released that shows only active time to get an accurate time/distance? Thanks for developing!
