App: Pool Swim
https://apps.garmin.com/es-ES/apps/f134a024-6ee4-47d3-8aec-3a397e3c9733
Track your pool swimming activities with your FR230 and FR235.
You can find the user guide and get support here: https://danipindado.github.io/Garmin-ConnectIQ-pool-swim-app.html
Credits
Icon made by Freepik from www.flaticon.com
You can donate my ConnectIQ development via PayPal here: https://bit.ly/2h1EMT1
Changelog
v1.0-upd.1: bugfixes. heading might drift sometimes.
v1.0-upd.2: improve heading calculation. new multicolor icon.
v2.0: support FR630. HR data.
v3.0:Initial support stroke count (feature as beta, waiting for your feedback). Several changes in memory managment and process execution for better performance and stability.
v3.0-upd.1: fix issue. data needed for stroke count analysis was not properly written in fit file. otherwise same functionality as v3.0
v3.1: discard menu: when exiting app, now you can choose between resume/save/discard.
v3.2: display summary window when paused.
v3.2-upd.1: fixed bug: duplicate lengths after triggering manual lap.v3.2-upd.1: fixed bug: duplicate lengths after triggering manual lap.
v4.0: most common pool length values and watch screen format & fields can be configured in watch. hold "up" button for three seconds. small adjustments heading. Several cosmetic changes.
v4.1:
calories can now be selected as screen field in watch menu.
new app setting "DEBUG" which enables writting of accelerometer and heading data @10Hz in FIT file (default disabled)
new feature autolap can be configured in watch menu (default disabled- when enabled, it triggers a new lap every n lengths, where n is a configuration parameter)
several bugfixes and memory enhancements.
v4.1-upd.1: bugfix calories calculation which caused crash when hr monitor is available.
v4.2: new FR630 key definition. improve how pace charts are displayed in Sport Tracks. See https://danipindado.github.io/Pool-Swim-app-v4.2-released.html
v4.3 Implement imperial units. Improve heading calibration. https://danipindado.github.io/pool-swim-app-v4-3-released.html
v4.4 Memory & stability improvements. new heading filter. stroke counting temporarily removed. https://danipindado.github.io/new-pool-swim-version-with-improved-length-detection.html
v4.5 New stroke rate algorithm. Small bugs and improvements. https://danipindado.github.io/stroke...pool-swim.html
v4.6 Garmin swim watch compatibility: recording continues during pause and stroke rate takes one arm into account only. heading chart shows now sine instead of rad. intensity field added (only 3rd party sites supporting ConnectIQ, f.i. sporttracks) https://danipindado.github.io/pool-swim-apps-improves-compatibility-with-other-swim-watches.html
v4.7 update summary window. update user guide. https://danipindado.github.io/Garmin-ConnectIQ-pool-swim-app.html
  • a mi me da mal la lectura. me da mas de lo que realizo.
    buenas Jesus,
    necesito mas informacion para saber por que no te va bien. te has leido el articulo de los chicos de la bolsa del corredor? explica muy bien como funciona el app:
    http://www.sport.es/labolsadelcorredor/pool-swim-app-connect-iq-natacion-piscina-garmin-forerunner-230-235/
    si a pesar de todo no te va, ponte en contacto conmigo y lo miramos. lo mejor es que desde la pagina del app,
    busques abajo a la derecha donde pone "Comuníquese con el desarrollador" y lhagas click. de esa forma me llega un email y ya te respondo.
    estamos en contacto
  • Hey there!
    Having just aquired the vivosmart HR, is it possible to use this app there as well?
    hi,
    actually vivosmart hr is not supported. but you dont really need my app, do you? the vivosmart hr already has a pool swim mode...
    Former Member over 8 years ago
    hi,
    That's correct, but it lacks some of the features I find useful (manual lap counting as the automatic count is not very precise and cannot be changed in garmin connect afterwards; no heart rate monitoring, etc), so I thought I'll see how other apps perform. ;-)
  • That's correct, but it lacks some of the features I find useful (manual lap counting as the automatic count is not very precise and cannot be changed in garmin connect afterwards; no heart rate monitoring, etc), so I thought I'll see how other apps perform. ;-)
    i see.
    well, sorry, i dont plan to add support for other watches. i have very limited development time, and i myself own a FR230. therefore i want to focus on that.
    I wish i had a vivoactive hr! :)
    i see.
    Totally understandable, thanks for the quick answer!
    For me it looks good. I hope that I will be able to test it myself in the near future. Of course I will let you know how it went. Keep your fingers crossed :D
  • I had quite a long break from swimming but I'm back. I was happy to notice it's already a feature "auto-lap". I see that stroke count also works very well. In general, this application works flawlessly durning my last sessions so hats off to you and thank you for you hard work :)
    Although I have a few observation.
    I noticed that after pressing the stop button (at the end of workout), the time still goes on until I save a session. Unfortunately browsing through menu takes a few seconds which are added to the total result (in sport like swimming those few seconds it's quite a lot ) On the other side, very often after training I'm able only to press only one button ;)
    Second thing: Maybe more useful will be to swap "time of the day" with "total time" on the main screen (with summary).
    I hope those changes will be useful for other users too.
    Greetings
  • For me it looks good. I hope that I will be able to test it myself in the near future. Of course I will let you know how it went. Keep your fingers crossed :D
    Cool,
    Enjoy the swim, go back and report ;)
    Greetings
    About the first thing: cool, great and very detailed observation. I will look into it.
    As for total time: it was there till a couple of weeks. Lot of people were requesting time of day, and I just replaced it by a random field, being it total time. Now clearly I chose the wrong one: several users are requesting total time back. Therefore I will bring it back in the next version. I will delete something else :D
    buenas Jesus,
    estamos en contacto
    hola de nuevo. he puesto el auto lap a 1 vuelta y ahora me va PERFECTO. MUCHAS GRACIAS
