App: Hiker
[FONT=Arial Black]Hiker[/FONT]
https://apps.garmin.com/en-US/apps/a230c855-7adf-415a-bb1c-289f27304563
Please use this thread for any questions and feedback.
Description
Hiker is designed for walking or scrambling outdoors. The app captures the hike data using the standard Garmin activities which can be uploaded via Garmin Connect. The activity is classed as a hike.
There is one main screen showing clock, timer, distance, steps, ascent and current heading. If a compass is present in the watch then the heading will display the current heading, otherwise it will display the direction of travel from the GPS trace.
Following this there are a number of graph screens:
  • Elevation
  • Pressure (Not available on the Forerunner watches)
  • Temperature (Using the Garmin Tempe temperature sensor)
  • Heart Rate
The data within these screens is sampled every 2 minutes which gives a history over the last 4 hours. The min, max and average values are taken from this sampled data. Any other data is read directly from the activity which you will see in Garmin Connect.
The last screen displays a trail as representation of the path walked. A data point is mapped down every 2 minutes when there's a good GPS signal. The start is represented by a green square and the current position is a red cross. Below the trail is the last known good position in degrees, minutes and seconds.
On starting the app it will wait for a good GPS signal which can bypassed. Use left and right swipes or the up and down buttons to move through the screens. Activities can be paused using the start/stop button. If you forget to resume the activity after a number of steps you will be asked if you wish to resume the hike.
Versions
v1.06
  • Added a breadcrumb trail of the hike.
  • Corrected the animation for up and down buttons.
  • Optimised the code to reduce the memory usage. This allowed the above trail feature to be added to all the existing supported watches.
v1.03
  • Added support for D2Tm Bravo, D2Tm Bravo Titanium, fēnix® 3 and fēnix® 3 HR.
v1.02
  • Added support for Forerunner® 230, Forerunner® 235, Forerunner® 630 and Forerunner® 735XT.
  • Added a heart rate graph. (Note: There is an issue with the vívoactive® HR firmware. This has been fixed in the beta release and will work in the next full release.)
  • Improved the display of the GPS status.
v1.00
  • Initial release for vívoactive® HR.
    Hi,
    I have Vivoactive HR and downloaded your app. I would like to ask if average pace could be added, I think it is a great feature, when walking.
    I have a question. Is Acent the elevation gain? If not, could be elevation gain added, please?
    I would love to pause and resume by using buttons, would this be please possible?
    Thanks you, great work!
    Jan
