Widget: IoTClient
Please post comments, problems, questions, and feature requests on the IoTClient ConnectIQ Widget in this thread.
https://apps.garmin.com/en-US/apps/da3db127-3938-4dac-bcf1-e30324fd0d20
  • 0.3.1 - upgrade
    I've upgraded to 0.3.1, and domoticz commands stopped working. When I launch the URL from the IoT app I get in the log:
    2017-03-27 21:25:16.259 User: Admin initiated a switch command (179/PC/Big/Toggle?)
    and no action is taken....
    when the same URL is launched from Chrome on the smartphone connected with the watch:
    2017-03-27 21:25:36.149 User: Admin initiated a switch command (179/PC/Big/Toggle)
    and action is launched
    I've checked with tshark and the actual URL has "? at the end:
    HTTP 277 GET /json.htm?type=command&param=switchlight&idx=479&switchcmd=Toggle? HTTP/1.1
    It shouldn't tough :)
  • Great App, works really well with Vera, just need to put phone on my VPN and it works from anywhere.
    Would be great to add support for Edge cycling computers, I have an Edge 820 and would love to have this on the Edge.
    More people have trouble with this. A workaround is add an "&" at the end of the url.
    Like this:
    json.htm?type=command&param=switchlight&idx=479&switchcmd=Toggle&
  • Fixed the issue! App is way more faster than previous verion, thanks Yennick1!
  • Access Denied
    Hi,
    when saving the URL in the Settings i get an "Access Denied" from the Settingsserver. Is there anything i can do?
    New Install of v 0.3.1 on iOS 10
    Hi Bernd,
    wann genau siehst Du diesen Fehler?
    VG
    Stenninger
    IoTClient with iPhone and Wi-Fi
    Hi all,
    this widget is pretty cool, I was quickly able to trigger some actions from my Fenix 3 HR using a python server script running on Raspberry Pi.
    However it seems I am experimenting some issues with Garmin Connect+iPhone, which are often disconnected from the wi-fi network when the phone is in stand-by mode, so preventing the client to communicate with the server.
    The only solution I found so far is to get up from the sofa :-( , get the phone and unlock it before acting on the watch, which as you can understand is quite inconvenient.
    Any suggestion to improve the effectiveness of the setup?
    Regards,
    Nicola
    Access denied problem
    ...if you see a "Access Denied" page while saving the app settings, please try to update the widget!
    This did help in my case!
    I'm trying to wrap my head around getting this to work with the Home-Assistant RestApi platfrom.
    Here's a sample curl statement, how would you convert this to be used with the IoTClient?
    $ curl -X POST -H "x-ha-access: YOUR_PASSWORD" \
    -H "Content-Type: application/json" \
    -d '{"entity_id": "switch.christmas_lights"}' \
    localhost:8123/.../turn_on
