Data Field : SwimmersField
# SwimmersField
Thread to report any issues you are having with the SwimmersField Data Field.
This datafield has increased font size for distance value so it can be easily visible under water.
This is a free Data Field for the Fenix 3 watch that shows three values as a single field or as a top field of two fields layout.
SwimmersField is open source, its code can be found at github: https://github.com/vovan-/swimmer-datafiled-garmin
Release versions are published in the [Garmin App Store](https://apps.garmin.com/en-US/apps/5db64fb4-6562-46ad-87a3-b88b122733cb)
## Features
* Timer: duration of the activity in [hh:]mm:ss;
* Distance: large font elapsed distance in meters or yards based on system settings;
* Time of the day;
* Unit settings applied only before starting the activity. During activity settings won't apply.
## Installation Instructions
A Data Field needs to be set up within the settings for a given activity (like Pool swim)
* Long Press UP
* Settings
* Apps
* Pool swim
* Data Screens
* Screen N
* Layout
* Select single field or two fields layout
* Field 1
* Select ConnectIQ Fields
* Select SwimmersField
* Long Press DOWN to go back to watch face
FAQ: How to add custom data field to app in fenix 3?
https://www.facebook.com/GarminFenix3/posts/441344592657118
## Usage
Start Swim activity.
You should see the SwimmersField Data Field.
## Changelog 1.1.2
* Reduced memory footprint
* Fixed error with displaying data field
## Changelog 1.1.0
* Initial commit
