Virtual Pacer
The Virtual Pacer data field helps you achieve your goals. Virtual Pacer shows all the information you need to cover the distance in the pre-set time. It's just as if you have your own personal pacer at your wrist.
You can get the Virtual Pacer here.
*********** Features ***********
- Allows you to set the required time and distance using the new App Settings features;
- Pace or Speed required to achieve your goal;
- Sliding bar showing you the percentage of distance covered;
- Option to change background color when you're behind;
- Shows achieved time, when finished.
Depending on the size you set the field, you can also have access to the following additional features
- Time or distance you're ahead or behind;
- Estimate of you end time;
- Remaining distance.
*********** Requirements ***********
Connect IQ version 1.2 or above
*********** Feedback and support ***********
Please consider this a beta version. I've tested this app successfully on Forerunner 920XT, Vivoactive and Forerunner 230, but since it's an advanced data field that's close to the boundaries of available resources, I'd like to do some more testing before I'll consider releasing v1.0. If you have any problems using this data field, please let me know.
General information about app settings can be found here.
*********** Version history ***********
v0.2: Included a lot of extra features, as described above.
v0.1: Initial version. Only shows required pace.
Setting up your goal time and distance in Garmin Express
  • Go to "Manage Apps", a list of all your apps is shown;
  • Look for the Virtual Pacer data field and press the "..." besides the data field name, a page is shown where you can change the settings;
  • Change the settings to the appropriate values:
    • Distance: set the distance. The number is interpreted as Kilometers or Miles, depending on your device settings
    • Time (hh:mm:ss or seconds): Set the time in seconds or as mm:ss or hh:mm:ss.
    • Show Speed in stead of Pace: The data field shows required Speed if set to true, else it shows pace
    • Show ahead/behind as distance in stead of time: Show how much you're ahead or behind as distance if set to true, else as time
    • Switch background color when behind: If set to true, the background color changes if you're behind => This setting has been removed in version 1.0 and is always true.
  • Press "Save" to save the changes. The new values will automatically be send to your device.
I you want to check whether the new values are saved to your device, you can simply go to the settings page again. Garmin Express will always load the settings directly from the device.
Setting up the zones in Garmin Connect Mobile
The following explanation is based on GCM for Android. GCM for iPhone should be (almost) the same.
  • In the menu go to "Garmin Devices";
  • Select your device from the list;
  • Select "Connect IQ Apps";
  • Select "Data Fields";
  • Select the Virtual Pacer data field;
  • Select "Settings" (if your device does not have Connect IQ 1.2 installed, you'll get a message "An error has occured");
  • Change the values (as described in the Setting up the zones in Garmin Express section above);
  • Select "Done" to save the values to your device
Same as with Garmin Express, you can check the settings by going to the Settings page again.
    Great, thank you TeunMo, now I have what I was looking for. I tried to test it this evening, it seemed to be working as expected but I had to stop my training in the middle and I couldn't use it as I wanted. But at a first glance it was ok. I'll tell you if something doesn't work properly.
    Thank you again!
    I'm happy you like the data field. I hope you won't find anything wrong with it, but if you do, or if you have any suggestions, I'd like to hear it. Thanks.
  • I'm happy you like the data field. I hope you won't find anything wrong with it, but if you do, or if you have any suggestions, I'd like to hear it. Thanks.
    Hello,
    I can't download the app from the app store
    I always have this message :
    'Sorry, the app wasn’t sent to your device because we’re having trouble communicating with our servers. Please try again later.'
    It's certainly cause by garmin server.
    I'm very interest about this datafield.
    Best Regards
  • The data field should work on an Epix.
    What do you mean by restart? Does your watch crash or does the data field fail? When does this happen? When you select the data field or when you change the settings?
    When i try to choose that field from menu it crashes epix and restart it. It strange because ConnectIQ Fields shows 1/3 (i have 1 active for 3 in my watch and it should be 1/4 because your field is 4th)
    Hello,
    Best Regards
    This problem is not related to the data field. Something similar happened to me once too. Restarting (power off) my watch helped.
    Thanks for the update. I don't have an Epix, but I'll try to look into this.
    Atacado
    Hi
    Could you explain the correct mode for configuration on VA?
    which field are avaiable?
    At the momento i can activate 2 field, CONNECT IQ 1/2 e CONNECT IQ 2/2 buth both fields shows the same data, distance ahead / behind and required pace to reach the target; now for test i have test 10 Km 45 minutes, the pacer show 4:29. It's not possible see in the other fields estimated time and distance remaning?
    could you help me?
    Thank you very much
    Hi
    Which field i could see on the 3 line screen of VA?
    Thank you very much
    On the Vivoactive you can see the following information:
    • Required pace/speed: The pace or speed required to finish in your target time
    • Ahead/behind in distance ((kilo)meters or yards/miles) or time
    • An orange bar indicating the percentage of target distance completed
  • Ok so it is discovered that Epix cant have more than 3 connect iq fields in system or it get reboot when you want to choose one :/
    So your field is fine.
    Brilliant Brilliant Brilliant !!!!!!!
    Thank you from the bottom of my heart, as a virtual partner is missing on the 235 and I am used to using the similar feature on my 920 it is just sensational that I can now use my 235 like my 920 but can confidently do away with wearing HR straps now. TeunMo, thank you.
