App : Triathlon
Hi,
I'm happy to present you my first garmin application : Triathlon.
Firstly for watch don't have multi-sport with 240x240 résolution : forerunner 245 & 645 and VivoActive 3.
With menu, user can choice their parameters for swim, bike and run.
Available in french (i'm french), english and espagnol.
    Former Member over 5 years ago
    Hi, it is possible to have an option to press twice the bottom to change transitions? Last duathlon the bottom was pressed by mistake in the bike and no way to go back.... thanks
    Former Member over 5 years ago in reply to Former Member
    ok ... i will look that for a next version.
    Hi! Congratulations for the app! I have a Vivoactive 3 watch, and as it has a tactile screen I am bit confused about the controls during the activity. I see that the physical button is used to move to the next step, but how can I pause the activity? is it pressing the screen at a certain zone or how? And how can I do to record every step (Bike-transition-run, for example) separately on Garmin Connect app, is that posible?
    Thank you!
    Hi,
    Thanks for your feedback.
    The possibility of pausing was not provided.
    With the actual developpement kit by garmin, it's not possible to separate activities like a native multisport watch can do.
    Best regards
    Former Member over 4 years ago
    Super app :) merci, ça va me faciliter la vie ! J’ai une petite question quand même ... quand je fais du run & bike, j’alterne course et vélo tous les kms pendant une dizaine de kms. Comment puis jefaire pour alterner dans l’application + de 2 fois ? Une fois que j’ai fait une fois vélo et une fois course, j’arrive sur le récap ? Merci :)
    Hola quería saber si se puede configurar para hacer duatlón. Pedestre bici pedestre
  • Bonjour yarolbzh, une question concernant l'app Triathlon. Elle est disponible sur Vivoactive 3 et 4 mais pas sur la version Vivoactive 4S.
    Cela serait-il possible d'ajouter cette compatibilité ou il y a une raison à cette limitation ?
    Un grand merci par avance.
    Cédric de Bordeaux Slight smile
    Former Member over 4 years ago in reply to Former Member
    ce n'est pas possible telle que l'application a été programmée : il est permis d'enchainer 5 sports maximum.
    Sí, ir al menú de la aplicación para configurar la "composición", luego elegir los 5 deportes ... o en tu caso correr, andar en bicicleta, correr y vacio.
    Former Member over 4 years ago in reply to Cedric33
    Bonjour Cédric,
    L'application n'a pas été conçue pour une résolution d'écran inférieure à 240x240.
    La Vivoactive 4s a une résolution 218x218.
