Widget : BigWeather
Welcome to
BigWeather
INTRO!
* Features
Displays weather information based upon your current GPS location. Supports 12 and 24 hour. Support metric and imperial. Supports C / F temperatures. Shows weather condition (icon and text), temperature (plus min and max temperature), humidity %, cloudiness %, wind speed and direction, pressure, sunrise and sunset times. Also shows a 3 day forecast (min/max temparature and humidity %).
* Notes
1) I rely on the weather data returned from a 3rd party (Open Weather API) so I cannot vouch for it 100%. Please don't leave negative feedback if the weather is incorrect, tell Open Weather!
2) If you *REALLY* want more accurate data (and/or) more weather data then one option is for you to pay for an API key for the 3rd party Work Weather Online service. Once Garmin allow customisation of widgets then I'll be able to switch to the World Weather Online weather feed. Until then please don't ask for stuff like 'chance of snow' etc as the free API doesn't allow this. Bottom line is if you want BigWeather to be far, far better then you'll have to be prepared to help me to help you!
USER GUIDE & FAQ
Want to know how to get the best out of BigTime or have a question, why not take a look at the User Guide and FAQ here
BUG REPORTS AND FEATURE REQUESTS
Please don't leave bug reports and feature requests when leaving feedback, please visit the Issue Tracker here
VERSION HISTORY!
Full version history is available here
IN CONCLUSION!
I am an independent software developer. I'm also a dedicated runner, passionate about my health/fitness and been an owner of many Garmin devices over the years (305, 310, 910, vivofit to name a few). If you would like to learn more about BigWeather see here www.boiledsweets.com/garmin
Now go, go run...
Thanks! :)
  • Official release 6.10 for the 920 is now out.
    Hoping this will allow an updated widget to be issued? Would be great to have it working again.
    Also the 920 now has now had Temperature added to the list of things you can set in Settings, Units. Can you use utilise this in the widget? I like to think deg C for temperature but miles for distance and pace. It is a British "problem"!!!
    Many thanks
    Tim
    It would be nice to get a status update from the BigWeather developer.
    Thank you, working perfectly now!
    Low and High always the same values
    Just got my 920 and loaded BigWeather. Love the widget. One issue I noticed is that low and high is always the same and equal to the current temperature.
    Known issue or I am don't something wrong? I can easily provide pictures.
  • Just got my 920 and loaded BigWeather. Love the widget. One issue I noticed is that low and high is always the same and equal to the current temperature.
    The data shown is from "OpenWeather", and they have an interesting definition of high and low temp. It's not daily high and low (That's what I expected when I first tried to use their data). So I looked into it.
    What it is, is the high and low readings of other weather stations close to the nearest station in the last reporting period. So you get the temp from the nearest, but if there are two more close by, it compares the three, and reports the high/low based on those three (it will probably be close, if not the same, all the time.) If there is only one station within the proper range, high, low, and current will always be the same.
    IMHO, "high and low" is kind of meaningless when you understand where they came from.
    Kim is correct however I think I could make a change and replace that with the forecast min / max, will post news here. Thanks for letting me know.
  • BigWeather 0.9 released
    See what's new here
    Written a user guide here
    Thanks a lot Rupert! Just got the update and to me it is a great widget!
  • Thanks a lot Rupert! Just got the update and to me it is a great widget!
    Cool. Glad you like it ;-)
