Application: Sailing
This thread is for any comments or questions regarding my Sailing application. Feel free to post suggestions for new features or bugs. Thanks for using.
Changelog:
#version 0.7
- added a startline screen that displays a countdown, distance and course to startline, ETA (see description)
- added support for D2 Bravo
- Layout updates for Velocity view
- 4 minutes countdown
# version 0.6a
- changed detail layout in velocity view
# version 0.6
- added support for Vivoactive
- added support for Forerunner 920 XT (experimental, Feedback needed via forum)
- Bearing calculation is adjusted (will be calculated every 0.01 NM)
- adjusted interface for the velocity view (former history view)
- Session recording starts after countdown finishes
- added countdown submenu
# version 0.5
- finalized Epix layout (with compass and MOB heading)
- stable MOB results
- race coutdown
- added calculated bearing value
- added Average and 10 second average speed
- improved compass display (the old one was to inconvenient)
- added an activity menu, from which activities can be saved, resumed and discarded
--- press start first time -> activity starts
--- press start second time -> activity menu is shown
# Version 0.4
- added vibration on anchor alert
- additional fixes on MOB (still instable, hope this will work better soon)
# Version 0.3
- fixed some MOB issues
# Version 0.2:
- added support for epix watch
    Former Member over 10 years ago
    First - Thanks for application. Very liked and donated to continue developing.
    I think its very good idea. Prefer to see on screen in big fonts - 10sec ( possible 20-30sec) average SOG (Speed Over Ground) and GPS ( not magnetic ) COG ( Course Over Ground ).
    Timer is very good idea and working well
    First of all, Thank you for your donation!
    You can see the 10sec average SOG in big letters in the velocity view (the one with the graph). Just press the start button to cycle through the values
    On the start view you can see the COG (Bearing) it is calculated from two GPS positions that have to be at last 0.01 NM apart
  • First of all, Thank you for your donation!
    If you can make them bigger it will be better and for me i prefer average 10s speed on top.
    May be you can do a little bit more in app compare actual speed and average speed 10s , if actual speed is greater then draw ^ near speed if less so draw V .
    Everything must be as big as possible i talking about letters speed 10s speed and so on because in the race you have no time to check watch you must see it without problems or without take your hand to you .
    Completely agree with pashka79 post !!!
    I have adjusted the layout of the velocity view. If you press start now you cycle through the values in the largest available font. There is no other information on the display during this time. No graph, no current speed ... . If you say that is what fits your needs (see screenshots) I will release it.
    It will be great. If possible to add COG (probably like compass in first screen ) it will be ideal :)
  • I have adjusted the layout of the velocity view. If you press start now you cycle through the values in the largest available font. There is no other information on the display during this time. No graph, no current speed ... . If you say that is what fits your needs (see screenshots) I will release it.
    WOW love it if you can add "^" "V" comparing with current speed it will be perfect
    Waiting to new version
    Sent you additional BEER
    :D
    Thank you very MUCH!!!
    How would you display the "^" and "V". If current speed is higher than AVG10 display "^" or the other way round?
    Time page
    hi!
    The page with the countdown and the recording is not fluid, i mean the Numbers remain the same until i push some button then it refresh.
    Is it normal?
    Thank you!
    hi!
    Is it normal?
    Thank you!
    I've recognized this behavior, too. I'm currently working on some advanced features for yacht racing (especially the startline feature). The view you are refering to will host this and I'll make everything work fluid then.
