Application: Sailing
This thread is for any comments or questions regarding my Sailing application. Feel free to post suggestions for new features or bugs. Thanks for using.
Changelog:
#version 0.7
- added a startline screen that displays a countdown, distance and course to startline, ETA (see description)
- added support for D2 Bravo
- Layout updates for Velocity view
- 4 minutes countdown
# version 0.6a
- changed detail layout in velocity view
# version 0.6
- added support for Vivoactive
- added support for Forerunner 920 XT (experimental, Feedback needed via forum)
- Bearing calculation is adjusted (will be calculated every 0.01 NM)
- adjusted interface for the velocity view (former history view)
- Session recording starts after countdown finishes
- added countdown submenu
# version 0.5
- finalized Epix layout (with compass and MOB heading)
- stable MOB results
- race coutdown
- added calculated bearing value
- added Average and 10 second average speed
- improved compass display (the old one was to inconvenient)
- added an activity menu, from which activities can be saved, resumed and discarded
--- press start first time -> activity starts
--- press start second time -> activity menu is shown
# Version 0.4
- added vibration on anchor alert
- additional fixes on MOB (still instable, hope this will work better soon)
# Version 0.3
- fixed some MOB issues
# Version 0.2:
- added support for epix watch
    Thank you RMZ84 for creating a sailing app. Great start!
    I would like to give some personal feedback to help improve or increase functionality of this app. It would be nice to have;
    • GPS tracking (like regular built in apps such as hiking, biking, etc) This is a great way to review your sailing trip. It would be beneficial for person to be able to track the line on the map and compare boat speed etc.
    • Start, stop, resume and save functionality. Would be nice to mimic built in feature.
    • Heart rate tracking data (even after saving activity)
    • Countdown timer - allow user to set a 10,5,1 minute countdown with alarms (great feature for starting races)
    Hope app popularity and development will grow.
    Thanks!
    Andrew
    Fenix 3
    Hi Andrew, thank you for your Feedback!
    • GPS Tracking is allready implemented. You can start it by pressing the start button after you received the first GPS data. But you are right, this is currently not very convenient. I will work on this!
    • A countdown timer seems to be what many people want to see. I'll implement this in one of the next versions
    • About Heartrate tracking I'm a little bit sceptical right now. I'll think about this one
    Best regards,
    Romano
    Tried
    Great start if you will add track saving like regular activity it will be great .
    If i pressed on strart button i see iq sign and nothing and app do not counting distance
    I use Garmin Epix
    Thank you !
    Pavel
    Hi Pavel,
    GPS Tracking and saving as activity is implemented but obviously causes an error on the Epix right now. Unfortunately it does not in the simulator. I will try to find a way to get some error log from the Epix. It would be great if you could provide me this data.
    Update:
    It seems to be pretty simple (I found it in this post: https://forums.garmin.com/showthread.php?210588)
    Another nice feature that we've made added is CIQ logging, which can help you with debugging on the device. Here's how you use it:
    Create /GARMIN/APPS/LOGS on the device
    Inside the LOGS directory make a CIQ_LOG.txt file
    This will log out console messages to the CIQ_LOG.txt file. You can also create a separate log file for each app, where any Sys.println statements called within the app will be written. For example, if your app is called MYAPP.PRG, just create a MYAPP.TXT in /GARMIN/APPS/LOGS
    If you could provide me the CIQ_LOG.txt file I will try to figure out, what causes the app to crash.
    Best regards,
    Romano
    Thank you
    This is great thank you!! I will install the app soon. Meanwhile i've just sent a couple of beers throught Paypall!
    Would be great if you'd implement, with the countdown, the start line too.
    Startline= two gps points
    The screen should show the remainig time, the distance to the startline and an indicator that tell you if at the current speed you will pass throught the line too early. Once started the screen should switch showing direction, race duration time, and speed.
    velocitek's prostart is something do the same (velocitek.com). Would be great have the same functions on my wrist been on the prow.
    Sorry my english.
    Ciao
    Alberto
  • Today i do an upgrade to software on Epix to 2.70 and app is not crashing i will try it in yachting tomorrow and will talk with you
    How can i see a saved track ?
    To save the track you need to press the start button again (red square is shown on the display). After synchronising the device it will be available under the standard activities in Garmin connect.
  • After last software update on Epix today 2.70 everything begin to work saving work start work
    If you will add a race timer and 10s average speed it will be perfect app to yacht racing.
    Thank you for hard work love this app!!!
    Pavel
    Foreword: I entered this forum by chance and with no intention and I didn't read what the IQ does.
    I am not a sailor but I am basically the wizard the sailing shop close to my place calls when he needs to configure a Suunto for one of their customers. :)
    The three most widely used apps are located here
    [Description]
    Sail tuning v1.0
    Sailing, Performance
    This simple application helps You in succesfull sail trimming. It shows instant feedback of trim impact by comparing Your current speed to Your last 10 sec average speed. If You managed to increase Your speed, You it get a posivite value (kn). Negative value means Your speed is decreasing. Display is updated every 3 seconds.
    here
    [Description]
    Race Start Timer : counts down from 5 minutes
    and here
    [Description]
    Sailors! Here is another magic APP for you! Actually - 8 APPs in 1! DISTANCE covered in nautical miles, distance to TARGET also in NM, SPEED in knots, DIRECTION offset versus the heading towards the target, VMG (i.e. Velocity Made Good) - the component of your speed towards the target, EFFICIENCY, ETA (Estimated Time to Arrival), current GPS ...
    I know nothing of sailing but it looks like everyone around these parts uses these apps. Surely the F3 can make a better job and since I stumbled here by chance I thought I'd give a suggestion to the DEV. :)
    The links should be accessible even to those who have no movescount account. I copied the description instead of the code because I don't suppose it's the same? Anyway if you need to see the code and can't because you have no MC account, drop me a PM and I'll copy paste it for you.
    Cheers!
  • Foreword: I entered this forum by chance and with no intention and I didn't read what the IQ does.
    [Description]
    Sail tuning v1.0
    here
    [Description]
    and here
    [Description]
    Cheers!
    Cool link!!
    [Description]
    Sail tuning v1.0
    here
    [Description]
    and here
    [Description]
    Cheers!
    Thank you for the suggestions! I think I will implement some of these features. Especially I like the Idea of a sail trimming helper
    Version 0.5
    I have updated the app with some new features and improved some of the existing.
    # version 0.5
    - race coutdown
    Currently I can't update the description and pictures. There seems to be a bug when uploading new descriptions.
