WatchFace: Horizontal Time
A simple watch face where hours and minutes are displayed horizontally and then stacked.
Original: https://apps.garmin.com/en-US/apps/15318739-b160-4b77-b51b-dafbd4ccb99d
Light: https://apps.garmin.com/en-US/apps/5890ff13-c4ab-4d48-9374-d248b14e794d
Red: https://apps.garmin.com/en-US/apps/0d27fbc7-f6ac-4592-8074-5802bc31177e
The watch face has these features:
  • 24-hour format only (due to design)
  • Day of the week
  • Date (Month and Day)
  • Battery remaining
  • Number of Steps for the day
  • Phone Connection (Bluetooth logo appears when connected)
Please let me know of issues or feature requests here and I'll do my best to accommodate.
  • Hi,
    After midnight, it shows 24:01 instead of 00:01. Can you fix it? :)
    Edited: after 01:00 the previous hour is 00 as it shoud be.
    Former Member over 9 years ago
    I will look into this. The original design inspiration was for 24-hr. If I can figure out a nice way to keep the design symmetry then I'll add that option for people who have their clock set at 12-hr. Thanks for the feedback!
    Great - thank you. Would also love to be able to select the minutes colour - red is VERY difficult to read in low light.
    One more thing, I've noticed that the watch is sluggish now that I'm using this watchface. When I press the up or down button to switch apps it takes often 2-3 seconds or more to switch. This problem was fixed immediately when I changed my watchface to something else.
    Thanks again
    We (okay, I :P) need this on the 920xt. We (I) really do. ;)
    Great work, I love it! (even if you can't get it to the 920xt ;) )
  • One more thing, I've noticed that the watch is sluggish now that I'm using this watchface. When I press the up or down button to switch apps it takes often 2-3 seconds or more to switch. This problem was fixed immediately when I changed my watchface to something else.
    i think this is not his problem. somebody else told that the new firmwares causing this problem if you use connectiq watch face. have you tried with connectiq face or with the standard ones?
  • Thank you sir!
    Fantastic watch face!
    Is it possible for you to add more collors to choose from?
    Its best watch face, but it would be awesome to change colors
    There are currently 3 versions. Please add yellow, green, blue
  • Thank you. Looking forward to it.
    I'm still working on it. One issue I'm having is that the EPIX fonts and screen resolution are completely different than the Fenix and D2. I'm not happy with how it looks right now although I might release a initial release to get feedback from users.
    I'm working on a second variation that uses custom fonts so that I can standardize the look and feel. I'll keep you posted.
    Not displaying the first 10 minutes of some hours correctly
    Hello,
    this is my favourite watch face and I "wear" it daily, so please, help me with my weird problem :(
    I have a problem with displaying the first 10 minutes of a hour. For example, the watch face displays 7:00, freezes it for the next 9 minutes and then jumps to 7:10. I'm sure, the problem is not with every hour. I've noticed it at 7th, 8th and 17th hour.
    I've almost missed my train because of this :D.
    I've noticed it on my fenix3 (with fw v4.60, also with v4.70) just some time ago. I'm using Horizontal time with black background, actual version. I've tried to reinstall it, but the problem still persists. Then I've tried to renew the screen during "frozen" time (switching to some widgets and back), but the watch face didn't show the correct time till the 10th minute.
    Could you, please, help me?
    And, 1 request to the end:
    I would like to have back 0:00 instead of 24:00. :)
    Thanks,
    Lenka
    Hello,
    I have the same problem with displaying the first 10 minutes of a hour. It freeze not the first 10 minutes. it is everything okay till 7:08 then the Watch show 7:00 and jump then to 7:10.
    Love the watch face but unfortunately I have the same problem as WALKINGFLOWER and stevie.i.
    To fix the problem I normally switch to a different watch face until the clock changes to the next minute and then switch back to your watch face. Normally that does the trick. I experienced it at 7, 8 and 11.
    It would be really great if you could fix that. :)
    Have the same issues with the bug, hope you can fix it soon because at this moment it is unsuable. ;)
    Also different colors would be great..
