WatchApp: pmTriathlon
pmTriathlon
pmTriathlon is a multi-sport app for triathlons. Designed to record a swim, a cycle and a run, with a transition inbetween (although the transition doesn't seem to create a FIT file, I'm assuming this is something to do with ConnectIQ).
IMPORTANT NOTICE
All this application does is start and stop events in the order that you do them in a Triathlon. This application has no control over data accurracy, that's handled by the watch. The swimming discipline seems to suffer the most problems.
These issues might be down to running on a Vivoactive (or other likewise watch); so if you're super-serious about your Triathlon data, you might want to consider a better watch designed for triathlons.
If you're happy with getting times as a minimum, then you'll be okay with this app.
Usage
Once started, the GPS will try and connect, the red bar above and below the phase chevrons indicates GPS signal, and will turn yellow or green when a signal is acquired.
To start your triathlon, press the "Enter" button (physical button on the right side of the vivoactive). Press this at the start and end of each discipline.
Press the button a final time at the end of your triathlon, and you will be presented on-screen with the total time, with phase split times.
Onscreen Data
Currently the only information available to display are:
  • Event (Total) Time
  • Discipline Time
  • Pace (time per mi/km based on watch setting)
  • Distance (mi/km based on watch setting)
Watch Support
It has only actually been tested on a Vivoactive, but should support all square screen watches
Downloads
https://apps.garmin.com/en-US/apps/e68063aa-d8b9-4801-9a26-633619f72a9a
Source Code
https://github.com/pmprog/pmTriathlon (MIT Licence)
History
v1.0
Initial Release
v1.1
  • A settings menu is now available in the pre-event screen by pressing the menu button. At the minute, the only option you are able to change is whether you are doing a Triathlon, Reverse Triathlon, or a Duathlon (Run/Cycle/Run); The data fields will hopefully get added soon
  • The screen is now locked during an event, and the only buttons that should do anything are the Power button (for enabling the backlight) and the Record button (for advancing)
    "Confirm" button for next stage?
    So does this app track the swim with gps ie suitable for openwater triathlons, or does it effectively use a method similar to the standard swim app, ie suitable for pool based triathlons
    I used it for a 70.3 recently and the swim seems to look pretty accurate on the GPS map. The only thing I did which was regrettable was accidentally press the side button during the ride (by my wrist being bent back on the bike section) which pushed me on to the T2 with no "undo".
    Pmprog: could you consider a "confirm" touch screen button after you press the side button?
    I've logged the issue here
    https://github.com/pmprog/pmTriathlon/issues/7
    So you'll be able to see progress. I will pre-warn you, it might be some time (if ever), as I have a lot on at the minute
    No worries - it's very much appreciated you take the time to do any of this at all! Thanks
    Custom mode
    Thanks for a great app making the VA even more usable!
    I would love to be able to choose the order of the activities in my Triathlon or duathlon. When training I often do bike-run-bike more likely than run-bike-run.
    It would also be cool to use it for swimrun-competitions. Setting up the number of runs and swimparts. For example a race which has 11 activities (6 run and 5 swim).
    The possibility to build combinations if you know what I mean. A custom mode :cool:
    swimming with glonass
    Has anyone done an open water swim with pmTriathlon and glonass on? Could it possibly increase accuracy in the water where the signal is bad?
    Custom mode
    I would love to see a custom mode allowing the user to set the order of activities. For example, run-swim-run-swim-run-swim-run-swim-run (for a specific swimrun competition) or bike-run-bike etc.
    I have thought about a more generic "Multi-sport" app, but I've done very little development for the watch lately (or for anything at all).
    We will see what time and motivation I get...
    You've improved the value and use of vivoactive with your apps. A flexible multisport app or extension of pmTriathlon would make you even more legend ;) Keep up the good work and hurry up to get motivated!
    I can assist with graphics and testing if needed.
    About time of transition
    I tried the app yesterday for the first time, and the application closed during the first transition.
    I made a test and realized that the tough transition time 1 minute and then the application is closed.
    It is possible to set this interval? Or is it a issue?
    tks
  • Hello , is there any way to configure the app for me to timing bike - run - bike?
    Grear work¡¡¡
