Looking for a developer that can get raw sensor data to our dashboard. Ideally, we like to use the lower end devices (e.g., not the fenix).
Hi, did you manage to get the raw data? I'm trying to do the same, but I can't find a way to go, could you help me?
If you look at the API for the Sensor module, that really tells you what access is possible.
As I said in the other thread, that's heart rate, and the array of heartBeatIntervals.
There is SensorHistory, but that's just an iterator over history where the heartRate is saved every minute or two.
The level of access it sounds like you are looking for would only be available in the firm ware, and not available in CIQ. Plus, on top of that, the firstbeat stuff is involved. Garmin doesn't allow the kind of access you are looking for,
Thanks for your answer Jim, do you know how to access the firmware?.
You don't. ConnectIQ developers are limited to the functionality provided by the ConnectIQ API.
