CIQ error DataFields RunScribePlus & StrydPower
forerunner 935 firmware 1157 beta
datafields RunScribePlus & StrydPower together in one treadmill activity application
both datafields connect to their sensors through their own ANT+ connection [no need to pair sensors, just provide sensor ID in GE, GCM setup]
Starting the treadmill activity always causes for one of the datafield a CIQ! error.
Is it possible to even have these two datafields running together. CIQ design specific?
Do these devs have to talk to each other solving, checking the error ?
happy hunting
Error: System Error
Details: 'Failed invoking <symbol>'
Time: 2018-12-10T19:56:03Z
Part-Number: 006-B2691-00
Firmware-Version: '11.57'
Language-Code: eng
ConnectIQ-Version: 2.4.2
Store-Id: c1f5c80a-5a05-4e8a-97b3-fda34e957035
Store-Version: 28
Filename: 87CC1E35
Appname: RunScribe Plus
Stack:
pc: 0x10000a9a
pc: 0x100007d6
pc: 0x1000051c
Error: System Error
Time: 2018-12-10T19:58:53Z
Language-Code: eng
ConnectIQ-Version: 3.0.4
Store-Id: 660a581e-5301-460c-8f2f-034c8b6dc90f
Store-Version: 50
Filename: DFD0C7C6
Appname: Stryd Power
Stack:
pc: 0x10000505
    hi @robertoandlaura,
    am also using Golden Cheetah but did not setup developer metrics
    sorry, can not help with WKO4+
    Scribe did a guess and said it could be related to the available memory for CIQ datafields.
    Forerunner 935 works with RunScribe Light and StrydPower datafields at the same time.
    as is today
    RunScribe Plus logs 11 developer metrics in the fit file (set to 1 visible metric(power) in datafield).
    • Impact Gs Left & Impact Gs Right
    • Braking Gs Left & Braking Gs Right
    • FootStrike Type Left & FootStrike Type Right
    • Pronation Excursion Left & Pronation Excursion Right
    • Contact Time Left & Contact Time Right
    • RunScribe Power
    RunScribe Light logs 7 developer metrics in the fit file (set to 1 visible metric(power) in datafield).
    • RunScribe Power
    Stryd Power logs 6 developer metrics in the fit file ( set to show 3s power in datafield)
    • Power
    • Cadence
    • Ground Time
    • Vertical Oscillation
    • Elevation
    • Form Power
    • Leg Spring Stiffness
